Let's get a few things straight, I'm not an installer, like you, I'm an LPG user. But I am a professional engineer (with letters after my name should I choose to use them) and consider that if a job is worth doing, it's worth spending a bit more time and care and doing it properly. I currently own two LPG cars and had another before. All three were bought ready converted but I wasn't happy with the standards of any of them. So, I ripped it out and put it back in again properly.RobTheShirt wrote: I don't drive my car to the limits so I don't know what would happen at the 'top end' nor do I care. I've always kept tight records of my fuel usage and the spreadsheet that I devised shows me that my fuel costs are around 55-60% of what it would be costing me unconverted and I'm more than happy with that.
I realise that you'll all be thinking I'm a friend of his but in truth, I only met him on that one day and have had no contact since. I also realise that some of you will be trotting out the horror stories about what has gone wrong in rebuttal.
My only regret now is that I didn't go to Gilbert instead. If only I could save 3 or 4 hundred pounds in just a few tank fulls I'd be a really happy bunny as I guess you all would! lol. I've always respected Gilberts knowledge and advice given on this forum but might I suggest that this was just a teensy weensy bit of an exaggeration :roll:
As for my comment on savings, I'll stand by them as I use my cars and make them work too. A tank of petrol is over £100 compared with a tank of gas at £45. As I go through at least a tankfull a week, that's not long to recover 300 quid. As for top end performance, the last long run I did in the P38 involved towing a fully loaded 3.5 tonne car transporter trailer from Cambridgeshire to the South of France, loading a different car on the trailer and towing that into Italy, then over the Alps through Switzerland and into Germany to drop the car off. The rest of the journey was done with an empty trailer. On that 4 day trip, I used 14 tankfulls of LPG and when slogging up the Alps, I was running at almost full throttle for miles on end. Any inadequacies in the fuelling system would have been shown up by either not being able to get up the hills or cooking the engine due to it running lean.
However, driving a run of the mill car gently isn't going to show up any shortcomings, so you are perfectly happy with your conversion. I doubt I would be happy with the standard of your conversion (having seen the gallery on the Profess website, I wouldn't be happy with a lot of them) but if it does what you want it to do and doesn't look like some of the ones shown on this, and other, threads, then I can understand why you think people are being unfair. It's when people have more complex cars converted using the same kit fitted in a rush that I feel that they do not do themselves any favours.
