COLLECTOR PRESSURE TOO LOW ??? What does this mean ?
On re calibration im getting a message saying collector pressure 0.19 too low, continue? what does this mean and how can i correct this, ive done 7000 miles on this conversion trouble free!
Stag 4 system on 2002 Toyota Previa 2.4 petrol/lpg
Re: COLLECTOR PRESSURE TOO LOW ??? What does this mean ?
that's to do with vaccum pressure, i'd check your vacuum pipe for leaks or the pipe come off the sensor.
tommo2009
- Intermediate Member
How can the Vaccum pressure be too low? surely it would be too high if it was a split pipe.
tommo2009
Not 100% sure but i would take a guess that it is the LPG pressure in the injector rail
Any suggestions for a fix assuming the vacume pipe is all good?
do I just up the pressure on the side of the vapouriser?
I thought that at first reading, so I went and looked in the manual, when it talks about collector it's on about vacuum pressure, they are polish so too low might mean it's near atmosphere and therefore not seeing enough pressure / vacuum.tommo2009 wrote:Not 100% sure but i would take a guess that it is the LPG pressure in the injector rail
Does it run on lpg, what vacuum and lpg pressure are you seeing at idle?adam1978 wrote:Any suggestions for a fix assuming the vacume pipe is all good?
if i continue then it calibrates fine and it will run on lpg without cutting out or anything!! allthough it has stalled once or twice recently.
map is reading 1.16 steady
It's broke.adam1978 wrote:map is reading 1.16 steady
What it should read depends on the circumstances, you might see 0.35 or so with engine idling and 1.0 with engine stopped.
Have you changed the sensor type in the software settings perhaps?
If it "done 7000 miles on this conversion trouble free" why are we tinkering ...
because it stalled a couple of times and had a battery change i plugged her in to see whats what' then that message appeared. what is likekly to be broke ? why does it run smoothly ?
"map is reading 1.16 steady" is telling you something is wrong. It should not read 1.16. It may not be anything physically broken, it might be a software setting changed or lost. If you wish to ignore it, that's your privilige of course.
tommo2009
A pressure reading of 1.16 is about right, a Vaccuum reading of 1.16 is wrong as Rossko says.
What is the gas pressure when running on LPG and what is the manifold pressure when on gas.
You've changed the battery so the ECU may have lost some of it's settings, check that everything is as it was.
It was doing the same just before battery change but I left it be as i was expecting it to be battery related dont know why.
