COLLECTOR PRESSURE TOO LOW ??? What does this mean ?
adam1978
#1 Post by adam1978 »
On re calibration im getting a message saying collector pressure 0.19 too low, continue? what does this mean and how can i correct this, ive done 7000 miles on this conversion trouble free!
Stag 4 system on 2002 Toyota Previa 2.4 petrol/lpg
sijones
Re: COLLECTOR PRESSURE TOO LOW ??? What does this mean ?
#2 Post by sijones »
that's to do with vaccum pressure, i'd check your vacuum pipe for leaks or the pipe come off the sensor.
tommo2009
#3 Post by tommo2009 »
How can the Vaccum pressure be too low? surely it would be too high if it was a split pipe.
tommo2009
#4 Post by tommo2009 »
Not 100% sure but i would take a guess that it is the LPG pressure in the injector rail
adam1978
#5 Post by adam1978 »
Any suggestions for a fix assuming the vacume pipe is all good?
do I just up the pressure on the side of the vapouriser?
sijones
#6 Post by sijones »
tommo2009 wrote:Not 100% sure but i would take a guess that it is the LPG pressure in the injector rail
I thought that at first reading, so I went and looked in the manual, when it talks about collector it's on about vacuum pressure, they are polish so too low might mean it's near atmosphere and therefore not seeing enough pressure / vacuum.
sijones
#7 Post by sijones »
adam1978 wrote:Any suggestions for a fix assuming the vacume pipe is all good?
Does it run on lpg, what vacuum and lpg pressure are you seeing at idle?
adam1978
#8 Post by adam1978 »
if i continue then it calibrates fine and it will run on lpg without cutting out or anything!! allthough it has stalled once or twice recently.
map is reading 1.16 steady
#9 Post by rossko »
adam1978 wrote:map is reading 1.16 steady
It's broke.
What it should read depends on the circumstances, you might see 0.35 or so with engine idling and 1.0 with engine stopped.
Have you changed the sensor type in the software settings perhaps?
If it "done 7000 miles on this conversion trouble free" why are we tinkering ...
adam1978
#10 Post by adam1978 »
because it stalled a couple of times and had a battery change i plugged her in to see whats what' then that message appeared. what is likekly to be broke ? why does it run smoothly ?
#11 Post by rossko »
"map is reading 1.16 steady" is telling you something is wrong. It should not read 1.16. It may not be anything physically broken, it might be a software setting changed or lost. If you wish to ignore it, that's your privilige of course.
tommo2009
#12 Post by tommo2009 »
A pressure reading of 1.16 is about right, a Vaccuum reading of 1.16 is wrong as Rossko says.
What is the gas pressure when running on LPG and what is the manifold pressure when on gas.
#13 Post by Gilbertd »
You've changed the battery so the ECU may have lost some of it's settings, check that everything is as it was.
adam1978
#14 Post by adam1978 »
It was doing the same just before battery change but I left it be as i was expecting it to be battery related dont know why. :(
