b) Laptop/software gives access to more fine-tuning parameters and diagnostic readings than the old box.
Is there some reason you are tinkering? Does anything make you think that settings have been lost?
software/cable would be handy to have in toolbox
tinkering with plugs leads rotor cap timing!!! in next few weeks. service.
May even do timingbelt same time.
car drives great after sorting fault with lambda *wire* pulled out.
i had takin it to cardiff to be sorted. they connected to computer and said could do no more untill i had a NEW lambda!! only 1 wire was off if they had looked at the connection. charged me for 1 hour work which was less than 5min.
when in carmarthen one day filling lpg tank i spoke with a guy there. customer. he asked me how the car was doing!! chit chat.!!
said i only doing 25mpg on gas , he was shocked . asked if i had a multimeter. opened bonnet. and moved a setting on the vaporiser *alenkey*
every fill up now im getting 29/30 mpg on lpg local or motorway driving loaded or not>!!!
would like to tinker with it to try and get a bit more mpg.
