Wanted Software for BRC Sequent 56 6 cylinder
As listed, if anyone knows where i can get hold of it, or has a copy, i'm sure they will be recompensed
Re: Wanted Software for BRC Sequent 56 6 cylinder
It used to be available here http://www.elpege.cz/software/brc/ but the website has had a redesign. A couple of weeks ago, there was no software there at all, now it appears to be appearing a bit at a time. If you are lucky, the Sequent 56 may pop up in the next few days.
Info: real BRC Sequent software requires a hardware dongle. No doubt there are hacked versions circulating in Russia, download at your own risk
Thanks guys i'll have to get my resident IT expert on it
Well i have obtained a copy of the software, just gotta see how much i can do with it, once all rigged up, either that or find a dongle somewhere
Does anyone know what is actually in the dongle on these?
It's a parallel port type
http://en.wikipedia.org/wiki/Software_protection_dongle
mat_fenwick
- Intermediate Member
Probably something like this then, just need to know which pins to link!
That'll be fun. Finding a computer with a serial port is hard enough these days but parallel ports disappeared long before serial ports did.
Probably not. They are not that simplistic.mat_fenwick wrote:Probably something like this then, just need to know which pins to link!
mat_fenwick
Dongles are programmed with security codes that match up to and enable the appropriate software or hardware.
In other words, when the software is booting, one of its commands can be to search for a valid security key (Dongle) before completing the start up process.
So therefore what your saying is if the authentication program is removed..............
Usually securely incorporated into the main program code. Of course it's only as secure as the coder makes it. Fairly well outlined on wiki here scroll to issues.
Software obtained (legally i may add lol)
Now just need to get the flippin thing working!
Hmmm drivers......off i go again lol
Hmmm sorry Rossko, i did post a reply ages ago, but it didnt appear.....strange, i meant for the interface lead, which i hmmmm was gonna say have, but my lappy died, so it's had :-/ anyways, it wouldn't work, still wont tbh, but i'm currently chasing wires, as there seems to be nothing coming out of the ECU even tho theres lives going in, so am still wondering if ECU is goosed
Hi, I' m fitting one of these right now, pm me and I'll share some details. Haven't talked to the ecu yet - tomorrow hopefully.
Regards,
Huw
Regards,
Huw
