I have a Twin Turbo Toyota Aristo
The car currently makes 400HP.
The body shape is the same as the GS300 / GS430.
I need an installer who will be able to fit an LPG system in the car.
anyone able to cost the system up
and recommend what type of system.
I am near Leeds.
thanks
LPG Kit / Installer recomendation
Re: LPG Kit / Installer recomendation
Did you get your car converted?
Could certainly convert your vehicle to run on LPG just like it does on petrol.
Would recommend an AEB based system with MJ injectors and 2 x pressure reducers. This system would be good for a 700bhp engine.
You also need a valve lube system fitted on your Lexus
Would charge £1395, job done. Can assure you of no issues!
Regards,
www.Lpgc.co.uk
Regards,
www.Lpgc.co.uk
