Trip To Norway Via Germany and Denmark.
I've had a search with some success, but could any of you good folk on here advise on the fittings required for traveling in these countries and what sort of availability of LPG there might be. Many thanks.
Re: Trip To Norway Via Germany and Denmark.
Can't help with Norway or Denmark but most of Germany and Belgium uses the Acme screw fitting, whereas Holland uses the same bayonet fitting as us and the rest of Europe use the Italian Cup. Your best bet, assuming you already have a UK bayonet fitting, is to get an adapter for both the Acme screw and Italian cup. That way you'll be able to fill up anywhere.
Thanks Gilbertd. An Acme is ordered from ebay. Already have a cup filler from my excursions to France and Spain.Gilbertd wrote:Can't help with Norway or Denmark but most of Germany and Belgium uses the Acme screw fitting, whereas Holland uses the same bayonet fitting as us and the rest of Europe use the Italian Cup. Your best bet, assuming you already have a UK bayonet fitting, is to get an adapter for both the Acme screw and Italian cup. That way you'll be able to fill up anywhere.
From what I can find on the net Denmark looks virtually LPG free and even if you can find it, it's pretty much the same price as Unleaded
On a run fully loaded the Classic can normally eek out 500 miles on it's 130 litres of gas so this will help and with 4 to share the costs a bit of petrol running won't be so hard to take.
Much like Switzerland then......Rubens wrote:From what I can find on the net Denmark looks virtually LPG free
Here you can find service stations where LPG is available in Denmark. ( yes those are all.....)
UnoX, Fuglebjerg Sandvedvej 3 4250 Fuglebjerg 5545 4929
UnoX, Middelfart Assensvej 105 5500 Middelfart 6441 2171
UnoX, Jels Haderslevvej 59 6630 Rødding 7455 2158
UnoX, Rømø Vesterhavsvej 15 6792 Rømø 7475 5328
UnoX, Ry Brunhøjvej 2 8680 Ry 8689 1022
Næsby Autoservice Bogensevej 23 5270 Odense N 6618 1303
LPGguiden is the Web page that has a complete overview for Norway and Sweden. It has a high refresh rate. It also has a price barometer and shows which connection stations are using.
The guide is objective regardless of supplier.
Norway 133 LPG refuelling station
http://www.gjelstenli.no/lpg/FyllestasjonerNorge.htm
http://www.gjelstenli.no/lpg/Fyllestasj ... age634.htm
Sweden 22 refuelling station
http://www.gjelstenli.no/lpg/FyllestasjonerSverige.htm
Sig
Note: English is not my first language. I use google translator.
LPG cars:
Chevrolet Suburban 5,7 - 1996
Mercedes E220 - 1996
LPG cars:
We've just completed our trip through the countries you mentioned.
The links provided by Chevy-LPG are to the site that we used, which proved very accurate.
Basically, we found Denmark to be more or less not worth the hassle of looking for lpg,
Norway is pretty good, Sweden is more difficult but do-able,
Finland, it doesn't exist.....
