one of them people that like to play with cars
dannyf
#1 Post by dannyf »
well I am one of them people that like to play with cars
and engines making them go faster ect ect :shock:
after a few beer's I got my tools out 8)
2 hours latter in the workshop
then :P
pistons an rods arrow rods
crank back from frozensolid
Block was also done
all build up with a new gearbox and atb diff fitted
started making it flow more air std
one been made bigger
now speed sorted out lets make it slow down faster
330mm x32mm with 4 pot's
then I found I could fit a 345mm x30mm kit under 17's so this is just as good for fast road use
as my Alcon 6 pot 343mm kit and less then 50% of the cost
rears have also been changed to vented rears at 292mm with custom made plates
a bit of cnc work sorted
new vs old
I do get some help in the workshop but he sleeps a lot
next stage is to fit a LPG kit to the car
started by painting the filler cap
and a shopping list like a boy racer has
I will do a update when i get the rest of the lpg stuff fitted
Re: one of them people that like to play with cars
#2 Post by Gilbertd »
The mans a nutter!
Just my sort of nutter though...... Where are you?
dannyf
#3 Post by dannyf »
Gilbertd wrote:The mans a nutter!
I am down in Hornchurch essex
the car started off with 192bhp when it was new then I have had it upto 329bhp and it will now do over 160mph
on a runway in england with a track day
if I do stick most of the kit in my self I have this car to copy
dannyf
#4 Post by dannyf »
All done now
I will move some stuff around when the new inlet manifold is made as it will free up some space at the rear of the engine
when the car was up in the air it has had some R&D done to the rear bush in the beam on the back
gone is all the Rubber :lol: and in its place a Block of steel with critical bearing
tommo2009
#5 Post by tommo2009 »
My corsa combo will quite happily go off the clock( speedo that is) 1.7 non turbo all I have to do is put it on the ramp lift it off the ground and run it up in 5th it really will go off the clock. Fastest combo i know LOL
dannyf
#6 Post by dannyf »
would I go on one of them Runs again errr not in my car :lol:
it running around town most of the time on a lower map
I built it to show some you dont have to spend a lot of cash with big tuners to have a fast car
MobileLPG
#7 Post by MobileLPG »
Loving the 'shopping list' on the door :wink:
Edward.
Nissan Skyline R33 GTR 450-500bhp (The only lpg converted R33 GTR)
Volvo V70 T5 310bhp, 40,000 trouble free LPG miles.
Chrysler Voyager, Converted with spare LPG parts lying around.
2006 Ford Transit connect LPG.
'56 VW Caddy Diesel
billynoband
#8 Post by billynoband »
Will the Keihin injectors manage 80hp per cylinder?
Cool car though, my Zafira is a 1600. It's pants.
dannyf
#9 Post by dannyf »
billynoband wrote:Will the Keihin injectors manage 80hp per cylinder?
Its doing fine on LPG with No real problems
it might pop back to prins uk for them to look at it
it hit 309bhp on LPG the other day not bad at all
dannyf
#10 Post by dannyf »
still going fine on LPG no problems at all
on the zafira a few friends with the same engine want to have this done now
N_Willmott
#11 Post by N_Willmott »
What does the frozen solid treatment do?
Cheers.
Nige.
dannyf
#12 Post by dannyf »
N_Willmott wrote:What does the frozen solid treatment do?
Cheers.
Nige.
just makes it a bit harder
the car is going to change a bit more now
the head will come off as i am going to change the cam belt and i will clean it all up or i will use my other engine an build that with Arrow rods an std pistons
a solid flywheel an sprung clutch
and the turbo will get changed for a T35 turbo and i will see if i can get the lpg system to work with a omex710 ecu system
dannyf
#13 Post by dannyf »
with the lpg system in the car is set up how i want it now with afr's are fine :)
got a few bits to fit to the car again
a sump plate off a police car
I changed the trim around in the car from part to full leather
so i needed to move the lpg switch
you would not know it was lpg now sitting in the car
new seats
the front ARB was changed from 21mm to 24mm
I am also playing around with the Dash looking to change the clock's from white to Black with 4 led's at the bottom of the fuel gauge for lpg or i mights just leave the switch in its new home under the ash tray
I removed the yellow filter on the card with sand paper now they light up with led's in blue or red not made my mind up yet
I also had a small water leak inside the car from the aircon drain getting blocked :lol:
and some of the lpg stuff is in the way to get to it from above in the engine bay its hard at the best of time so
think like the A Team
use some pipe work and a airline to blow the @!## out jobs a good one
vauxhall book time to fix it 12 hours my way 30 mins
dannyf
#14 Post by dannyf »
got a few more bits to change on the car ie
the Turbo is going to get changed again for a T35 turbo
with a new manifold i should get this done some time soon when the car is back from the body shop as its in for the front bumper to get replaced
sportston
#15 Post by sportston »
I'd love to do some of those type mods to the engine on my Alfa. I'm sure 200bhp can be near doubled on a 3.0 V6. Then maybe mine will go off the clock too.
mat_fenwick
#16 Post by mat_fenwick »
This is a more interesting way to get 400 bhp from a 164...
sportston
#17 Post by sportston »
mat_fenwick wrote:This is a more interesting way to get 400 bhp from a 164...
Wow. Cool! Who did that? Will have to post it on the 164 forum.
mat_fenwick
#18 Post by mat_fenwick »
I read about it in an AROC magazine some years back, and there's not that much about it on the internet. Here's a bit from a forum, and here's a brief video, although wrongly described as a 75...
dannyf
#19 Post by dannyf »
I also had a play with the Black lpg one
i have had a 6 speed box for years an he has wanted one for a long time so i did this when he was off work
did a gearbox change 5 speed to 6 speed
