Is there anyone in the grantham area who can offer me some cheap guidance ??
I have a 2002 preivia and im struggling with the wiring to the petrol injectors, everything else is done.
Yes, you need to identify which one has an ignition switched 12v supply on it and leave it alone, it is the other one, the negative that you need to splice into.adam1978 wrote:i have two wires to injector number 1 from the main loom I understand i need to find the positive/negative etc.
Well the picture is about as clear as it can be. You have two wires from the petrol ECU to each injector, one of these will be the positive. As I know nothing much about the Previa, lets assume they use the same arse about face logic as Ford and say the black is the ignition switched positive (and not negative as standard DC wiring would assume). In that case, leave the black alone (this is the one shown on the diagram as the wire with a + next to it that just sort of hangs in mid air) and cut the other wire, the yellow in your case (I assume the other injectors are black plus another colour, in which case it does use the arse about face Ford logical colour code). You also have two wires coming from your LPG loom that need to go to injector 1. Connect the yellow one from the LPG loom to the cut end of the original yellow wire that goes to the petrol injector and the black one from the LPG loom to the cut end of the original yellow wire that goes to the petrol ECU. You are intercepting the pulses from the petrol ECU to the petrol injectors. When the engine is switched to run on petrol, it simply connects these wires together so the pulses goes from ECU round a big loop to the LPG ECU and back to the petrol injector. When running on gas, it breaks the loop so that the pulses are used to trigger the LPG ECU to tell it to fire the gas injectors and never get anywhere near the petrol injectors so they stay shut.adam1978 wrote:But I have one yellow one black for injector 1 also i have 1 yellow and one black all from lpg loom.
just dont know how to get these for wires into two?? the picture doesent really help.
I can't quite work out how you could have cut 2 wires, added two more (which would give you a total of 6 ends) and joined them back together in such a way as to have ignition switched positive and a permanent negative at the petrol injectors, but it seems you did. As soon as you turned the ignition on, the petrol injectors opened and you managed to fill the combustion chambers.adam1978 wrote:I did it how i thought was right but have flooded the engine :(
I pulled the black wires and yes they came straight out so that helps!! less wiresDualtech wrote:I think the black wires you are refering to are on the gas loom? If this is correct then you can ignore them, if you delve a little deeper into the wires you will see that all they origanaly did was to loop from one plug to the other/before you cut the plugs of the loom/ this was simply to connect the positive of the petrol injector from one plug to another. Give them a tug and see if them come out. If they do infact go all the way back to the gas ecu then it could be that the system allows you to select the +/- polarity of the plugs, altough I doubt it, But if this is the case then just join the ends together.
I dont know if its the same but the colours actually correspond with each cylinder on an italian system. Just worth bearing in mind.adam1978 wrote:I pulled the black wires and yes they came straight out so that helps!! less wiresDualtech wrote:I think the black wires you are refering to are on the gas loom? If this is correct then you can ignore them, if you delve a little deeper into the wires you will see that all they origanaly did was to loop from one plug to the other/before you cut the plugs of the loom/ this was simply to connect the positive of the petrol injector from one plug to another. Give them a tug and see if them come out. If they do infact go all the way back to the gas ecu then it could be that the system allows you to select the +/- polarity of the plugs, altough I doubt it, But if this is the case then just join the ends together.
I have found the wire with 12v so have put back to the injector as it was, the solid colour (yellow) to negative injector then the mixed colour (yellow/black) to the ecu wire.
same for all the other injectors, is this right???
I have put it all back together and tried to start on petrol but no luck, it did cough and splutter as if it was going to then the battery gave up.
Yes I connected the pump relay!!
The smell of petrol is back so ive taken the plugs out but they look drier than the first time, so hoping its just the battery not having enough clout.
