zavoli lights going out after 15 seconds
hi everybody im paul from bradford and new on here. I have just fitted a zavoli zeta s to my 3.5 v6 espace fitting went really well apart from this problem when i start the car the lights on the swich work as they should. with the petrol light on the switch and if you press it the gas light flashes as it should but after 15 seconds all the lights go out. but the car still runs as it should.Please help!!!!!!!!!!!!!
Re: zavoli lights going out after 15 seconds
Is it running on gas or does it drop back to petrol? Lights going out after a few seconds and dropping back to petrol usually means no input from the ignition coil.
Sorry i have not made myself really clear i mean it has not run on gas at all because it seam to turn its self completely off after 15 seconds thank you for your quick response
tommo2009
- Intermediate Member
it is not seeing an RPM signal or ignition live signal. plug your laptop in and check you are getting all the correct values
