discovery airbox
welshphill
discovery airbox
#1 Post by welshphill »
i've heard that an alternative to the plastic airbox found on discoverys, you can fit the round metal ones from either a range rover classic or an early/200 discovery...
my plastic airbox fitted to my 95 3.9 v8 discovery has a rather large crack in it from a lpg related blow back
has anyone else heard of or tried out this mod???
is it a straight swap or should it be modified in any way (cat flap)????
mat_fenwick
Re: discovery airbox
#2 Post by mat_fenwick »
Or a K&N (other makes are available) type cone filter? Copes with blow backs better!
The other option I've heard of for protection is to fasten the airbox lid down with a bungee cord, so that it can lift off if a blow back occurs.
tommo2009
#3 Post by tommo2009 »
you need protection for the airflow meter, not just the airbox, a damaged airbox won't stop the car running and airlow meter may well do
admin
Former Site Admin
#4 Post by admin »
I fitted one of the cylindrical ones to my Discovery after the plastic box was blown to bits. It worked really well and I secured it with a bungy cord. I have attached a picture.
Damian
mat_fenwick
#5 Post by mat_fenwick »
The later Hotwire AFMs are more robust than the early flapper style - I suffered a few on a previous Disco with no AFM damage, although obviously better to protect it.
welshphill
#6 Post by welshphill »
would a 200 tdi round metal airbox be ok???
welshphill
#7 Post by welshphill »
how do i go about protecting my AFM???
admin
Former Site Admin
#8 Post by admin »
AFM ?
welshphill
#9 Post by welshphill »
Air Flow Meter
admin
Former Site Admin
#10 Post by admin »
The little gauze thingy stays in place and you just connect the new filter box using a jubilee clip to the existing hose. Voila.
