Is this real
bodge-it
Is this real
#1 Post by bodge-it »
Hello all,
1st post onto the forum so novice all round... ( please advice of my mistakes ) ... don't want to upset..Hope this post is in the correct place...sorry if not
I've just been looking at vauxhall's figures for petrol vs lpg on the zafira 1.8ltr and wonder if anyone finds it strange:
extra urban-- petrol 43.5mpg current price round here £1.30
extra urban-- lpg 31.00mpg current price round here £0.75
Not close to the normal accepted 10% less mpg on lpg more like 28%
so over a 1000mile trip on petrol it would cost £135.98p ,, lpg £110.08p
a wild saving of £25.90p to lpg.
I've just had a quote to fit 2 lpg filters and adjust the vaporiser = £220.00p :roll:
payback on this with the £25.90 saving on lpg would be 7723 miles of gas before I start saving again...two years to me...hoping nothing major goes wrong..
So is gas really the way to go with the gas service costs so much and on TOP of the normal vehicle servicing costs..
Now I don't know where vauxhall got there figures but my Zaffy don't do close..
Also anyone know ( i've been told) :evil: a carsonagenic gas is put in the vaporiser and not to try and refurbish it ,
VERTON gas ,, not found it on google or anywhere .. ? legpull ?
:oops: Sorry to go on so much and probably duped a lot of things delt with in the past....
Anyone know any koltec-necam filter suppliers for a 2004 factory fit zafira 1.8 ??
cheers
phil
Re: Is this real
#2 Post by Gilbertd »
bodge-it wrote:extra urban-- petrol 43.5mpg current price round here £1.30
The petrol figure seems extremely good for a 1.8 litre car but we all know that the quoted, laboratory generated figures usually bear very little resemblance to what you actually get. Have you checked consumption on both fuels to see what it actually does?
bodge-it wrote:I've just had a quote to fit 2 lpg filters and adjust the vaporiser = £220.00p
Sounds about double what I would expect.
bodge-it wrote:Also anyone know ( i've been told) a carsonagenic gas is put in the vaporiser and not to try and refurbish it ,
Scaremongering. The only things in a vaporiser are LPG from your tank, coolant and a bit of air from the atmosphere to sit behind the diaphragm.
bodge-it
Re: Is this real
#3 Post by bodge-it »
Hi gilbertd,
thanks for reply,
Figures for my car are motorway =petrol 37mpg .When it last worked a year ago lpg varied between 23 to 31 mpg ,at its demise it was 14mpg..
Even then the gas did not live up to the usual 10% gas petrol difference more like 20-30% which wasn't a great saving over petrol.Roughly same ratio as vauxhall figures.
Just got the gas flowing again to find whats wrong , So thought I would start with filters..
I thought the price a bit rich or he was...thats why I'm looking for someone who can supply filters.
cheers
phil
robertXX
Re: Is this real
#4 Post by robertXX »
bodge-it wrote:.
VERTON gas ,,
cheers
phil
hahahahahaha , that is an absolute classic , go back and tell them you'v heard its also radio active and creates huge growths !!
basically they are lying to you right ,left, and centre ,and massively overcharging for basic work ...tell your freinds !
pjpj
Re: Is this real
#5 Post by pjpj »
Give these guys a call if you cannot see what you need.
Regards
PJPJ
To help identify your Vauxhall LPG model, go HERE
Gremlin
Re: Is this real
#6 Post by Gremlin »
One thing I have found is thats its very difficult to work out the true MPG you are getting on gas..... why?
because it depends on the pump which is putting the gas into your tank...
Bentley started to run out of gas today so I went and filled it up..... All it would take was 50 litres.. That works out at nearly 14mpg...yehh!!!
I think the tank is a 90 or 100 litre. Not sure, so I think there was space in there for another 25 - 30 litres..
Stuzewheels
Re: Is this real
#7 Post by Stuzewheels »
Gilbertd wrote:[?
Scaremongering. The only things in a vaporiser are LPG from your tank, coolant and a bit of air from the atmosphere to sit behind the diaphragm.[/quote]
Don't mean to hijack this thread but as a newbie don't think I can put up a new enquiry.
Re your comment above I was thinking of changing my vaporiser with same make/part and wondered if this is a job I can do myself or need an expert? Water pipes no problem (no air lock critical) but not clear what needs be done before gas pipe can be loosened off? Are there any general guidelines on doing this task? Its an Emmegas for a single point system.
Stuart
bodge-it
Re: Is this real
#8 Post by bodge-it »
Its seems to depend a lot on temperature as to how much gas goes into the tank.Some days you win and some you lose..Worst fill I ever had was at a Morrisons so i don't fill at that one anymore.
I mainly used one supplier (FLOWGAS) cos I opened an account and get upto 10p of the price of other retailers!.
Although I havn't had any for a year now cos the Zafira has a problem running on gas...
cheers
john_d
Site Admin
Re: Re: Is this real
#9 Post by john_d »
[quote="Gremlin]
I think the tank is a 90 or 100 litre. Not sure, so I think there was space in there for another 25 - 30 litres..[/quote]
That's the shutoff valve in your tank stopping the gas, not the pump.
Sent from my HTC Desire HD, Powered by Android Revolution.
Ford Tourneo
Nissan Primastar
Gremlin
#10 Post by Gremlin »
john_d wrote:[quote="Gremlin]
Sent from my HTC Desire HD, Powered by Android Revolution.[/quote][/quote]
It must change its mind when I fill up at different places then....
bodge-it
Re: Is this real
#11 Post by bodge-it »
I'm 99.9% sure my shutoff valve in the tank (zafira 1.8 lpg factory fit necam) is stuck shut and will not allow any lpg in it..
last try couple of hours ago 0.23ltr only..
thats all i've managed to get in it on several attempts over the past year..
It was about empty last year when it stopped filling..
ran it another 100miles or so , now just runs for minutes before back to petrol...
Who can fix this or where do I start..
cheers
phil
john_d
Site Admin
#12 Post by john_d »
bodge-it wrote:Who can fix this or where do I start..
cheers
phil
You could try tapping the tank with a soft mallet, failing that you could try to remove the multivalve of you believe its empty enough.
Ford Tourneo
Nissan Primastar
Gremlin
Re: Is this real
#13 Post by Gremlin »
Still not managed to get more than 50 litres in my tank at the regular garage and not inclined to want to test it at another garage where its 20p per litre more.....
Its a 120 litre tank........thats a lot of price difference...
pjpj
Re: Is this real
#14 Post by pjpj »
If the other garage has three tanks as opposed to two you may find you can get more in.
Why not fill up at your usual place then travel to the other or a. another and see if you can get more in than the fuel you've used on the journey there.
Regards
PJPJ
bodge-it
Re: Is this real
#15 Post by bodge-it »
I think on this forum (could be mistaken) a guy found the float in his tank had cracked thus not floating as it should...can't remember the actual probs he had....bit of a waste of a post realy....but like to keep in touch....
PJPJ .. I've found a rusky manual in russian even ,about the earlier Koltec-necam ,is it GSI ,for your collection..its got pix and writings i've not had time to translate..
whats best way to get it to you ??
cheers
philg
pjpj
Re: Is this real
#16 Post by pjpj »
All information gratefully received, if I can figure it out it may well come in very handy.
I'll PM an email address if you could please.
Many Thanks
Best Regards
PJPJ
Re: Is this real
#17 Post by Gilbertd »
and if you need it translating Russian is my missus's native language......
bodge-it
Re: Is this real
#18 Post by bodge-it »
Hope these files got to you ok :) ? and are worth the effort ! 8) ..
pjpj
Re: Is this real
#19 Post by pjpj »
Thanks, I have received these OK.
Alot of the images I have got but I don't see anything in the text that I've seen before.
I have translated a couple of parts which is of interest concerning the filter in the solenoid valve at the vaporiser.
According to the standards the Netherlands filter element must be changed every
90000km (Apx. 56000miles) mileage or every 6 years. For Russia, this standard is 30000km (Apx. 19000miles)
This must be because it is so much colder. I never considered it an issue for the filters.
and
9.0 System Maintenance EGI
The first maintenance of the gas system EGI holds in the interval
14500-15500km mileage, or one year of operation.
Routine works include:
1. inspection of the pressure reducer-evaporator;
2. inspection of the filter in the gas valve;
3. clean the filter in the dispenser-distributor;
4. check all connections for leaks.
The second then the system is performed in the range 29500-30500km mileage car or two years
operation. It includes:
2. replace the filter in the gas valve and clean the magnet;
Subsequent maintenance of the system are performed at intervals of EGI 30000km mileage and repeat of the second TA.
Unfortunately, one has comments like this so it doesn't go into any depth.
On cars from 1997 model year set the computer with the new version
software. These cars can be diagnosed by using computer
through a special interface. Program for testing called MONIO. She
can read error codes, check out the most important signals of the system in real
Time and write the parameters of the engine dynamics. In case of need
diagnostic file can be sent to the Netherlands via email.
I shall be picking away at these and seeing if there are any other little gems in there.
Thanks Phil
and for the offer of translation help Gilbertd
Regards
PJPJ
bodge-it
Re: Is this real
#20 Post by bodge-it »
Monio sounds interesting,,
Just reading bits by 'KVER' on as*an*wner fo*um.
He basically intimates the monio software is interfaced to pc from the 4 wire connector in the fuse box/or/ switch area that has the grey diag wire in it..
and vauxhall official LPG repairers should have one !!.
All we need is the loan of one and a copy (ha!ha!)..
As soon as I have my scope built I will have a look at the signals from these wires and if its possible to knock something up .. I've had dafter thoughts over the years..
Once i pulled a teletext board from an old tv and interfaced it to a spectrum computer ,wrote software and a 40column screen driver so I could look at the teletext,worked a treat,thought I'd become a second Sinclair/sugar but a week later someone had one on the market..dreams shattered.
