do you mean this
Gilbertd wrote:it is the tank level sender that is driven from the gauge on the tank
so there a proper float inside that tank like a petrol fuel tank
Hear is a photo of my ignitioncoil
It has colors red/grn blk grn/yel
Which one connects to the system
Gilbertd wrote:
It is a loom with 4 male and 4 female plugs. You uplug the existing ones from the existing petrol injectors and plug these into the loom. Then you plug the other ones from the loom onto the petrol injectors. Just make sure you get them correct, cylinder 1 to cylinder 1, cylinder 2 to cylinder 2, etc.
is this what you mean
Although it dose not say the colors are as followed from the diagram
A red wht/brn: B red blu/wht: C red wht/red: D blk/wht
From the diagram we have no idea what color wires are for the cars and the LPG injection system
The colors for my injectors off my engine from D/S to O/S are
blk blk/brn: blk red/brn: blk grn/brn: blk yel/brn
Which wires do I connect to the system
but of corce we need to know what bloody color wire connect to them as diagram dose not say
Well hear are the spare wires I have from wiring loom from the kit
blu blu/blk red red/wwt red/blk grn grn/blk yel yel/blk
Do they make any sense to you
And found a fuse for my kit
But not in the diagram above dose not have a fuse on
What this manual rely needs is a dam good wiring schematic
In any language we would all be able to see what was going on instead of playing inspector cluedo
especially when its in Dobble Dutch
quote="Gilbertd"]You need one of these so you can connect your computer to the LPG system.
http://cgi.ebay.co.uk/Omvl-Dream-xxIN-L ... 53e26d7937[/quote]
do you mean this
Hear is a photo of my ignition coil
