I've heard that LPG doesnt perform well in the cold but my car ran absolutely fine today and the outside temperature was MINUS 14 !!!
Anyone having any problems ?
Stu
So you're actually better off leaving her ticking over until warm when the durations close up before driving off, rather than booting it from cold as the Eco-warriors would have you believe?junkcatcher wrote:Warm up and defrosting has a big effect on fuel consumption typically petrol injector durations are at least 25% longer immediately after a cold start. Coolant temperature has a big effect on required air/fuel ratio.
Well no, because leaving it ticking over burns fuel solely for warming up ; mpg = zero.Active_Lad wrote:So you're actually better off leaving her ticking over until warm when the durations close up before driving off, rather than booting it from cold as the Eco-warriors would have you believe?
Although when warming up and defrosting its normally still running on Petrol as coolant isn't warm enough for LPG switch-over.junkcatcher wrote: Warm up and defrosting has a big effect on fuel consumption typically petrol injector durations are at least 25% longer immediately after a cold start.
A 12mm (IIRC) single hex socket fits as well ! I have a better story about Rover V8s priming though - and also proof that they can actually self prime. I would welcome any explanation as to cause because I'm out of ideasmagneto wrote:BTW I have built a few Rover V8 engines, and if there is no oil already in the system the design is such that the engine won't produce any oil pressure. You can either fill the oil pump with vaseline, use a primer shaft or a secret other way which I may reveal...
I made a dummy oil pump drive shaft, and with an ordinary electric drill started this priming process. Admittedly with 20/50 oil, I quickly kippered the drill, such was the loading on it. I have never revved a cold engine high since!
Incidentally, if anyone here is changing the oil on a Rover V8, don't go for a cuppa while it's draining - you may need to go through this priming routine to get oil pressure.
Well I know that the richment tappers off in my Stilo after about 90sec after start up as thats when the rev's drop off and it returns to it normal 'warm state' rpm.junkcatcher wrote: The petrol ECU sets 25% longer petrol injector durations for cold start enrichment nothing to do with the LPG system, the richment tapers off as the coolant temperature rises only when the temperature of the coolant at exit from the cylinder head exceeds about 70c to 80c will the engine switch to closed loop most LPG conversion would have switched to gas before that.
An early one then - I think they changed in the late 70's to early 80's. Early ones had a drive tang on the dizzy and a slot in the pump shaft, later ones switched round to have a slot on the dizzy (on a flexible coupling to allow for any alignment errors) and a tang on the pump shaft.My shaky memory tells me that there are 2 types of oil pump gear? Mine had a slot, hence the tool.
Who knows - all I know is it was a strange oneMaybe your motor had some oil pump/pressure release valve issues?
OK, no-oone else will know about itI'll reveal my priming trick, but keep it to yourself...
Waay off topicGilbertd wrote:This means I'll probably be getting something like a 4.6 HSE. I assume that at that age the engine is still a development of the original Buick design? Does it suffer from this oil pressure problem and are there any other major flaws that I need to be aware of?
