I have a Jeep Grand Cherokee 4.7 1999 with a prins multipoint LPG system and I'm ready to admit defeat at trying on my own to cure this! Also this may not even be an LPG problem as it seems to happen on petrol also, but help would be greatly appreciated....
My car is slightly misfiring when at motorway speed (70-80) and only when under load.... the misfire gets worse when going up hill or switching the air con on or having the car full of people.
I have changed the spark plugs twice (now have a cooler set in) and also changed the coils (changed 4 and no difference, so changed the other 4 and still no difference).
I have had it plugged into a Jeep diagnostic unit and no faults were shown.
If I have the car under a very small load the misfire seems to be about once every second, but if I then put my foot down it misfires loads.
Not completely sure, but seems to be better when the car is first started.
As I said earlier it seems to happen on either gas or petrol so I'm pressuming it won't be anything to do with the fuel system, but did wonder if any part of my fitted LPG system could cause this?
Will post this on the V8 section as well in case someone misses it here
Many thanks in advance to anybody that can help me.
Mark
