Using Iridium plugs with my V6 Mondeo
blueoval
Hi all,
I need urgent advice if anyone can help, I'm looking at fitting Denso Iridium plugs to my Mondeo V6 but can't decide between the two types, Iridium Power and Iridium Tough.
Is anyone familiar with these and able to give me a clue as to longevity and performance of each type?
I use Denso Iridium Power, the difference is that the "power plug" has a smaller tip, so theoretically produces a better spark.
I Used the Denso Iridium Power in my Clio and had them in for about 40k with no problems, they are currently in my megane and have done about 12k on gas.
Not used the tough plug, but longevity seems good with the power plug
Cheers
Graham
Cheers
Graham
blueoval
jalfrezigazee
blueoval
ryncharlton
- Junior Member
blueoval
Well now that they're fitted I can say that the car is nice and responsive, it's running lovely in fact. However, it always does when it's just had new plugs fitted, the proof will be in their longevity.
It seems that some people have noticed significant improvements by fitting the Iridium ones. I would say to give it a bash, they're not ridiculously expensive, and if it means the service interval can be increased then so much the better!
Sir Henry
blueoval wrote:That's very reassuring thanks, I've ordered the Power plugs today as I got 6 for just over £40 delivered from Opie. Fingers crossed they'll do the trick then!
Sir Henry
Even with the 5% introductory discount a set of 8 IW16's come out at £67 or so. I can get the NGK equivalents (BPR5EIX) cheaper off eBay!
So far my best quote is under £50.
*Update*
I have just bought 8 of the NGK Iridium plugs from "autoorders" on eBay for £47.17 inc. postage. He may have other flavours in these plugs.
*Update*
