How much is LPG in your area?
Sir Henry
#141 Post by Sir Henry »
If you live in the better part of South Yorkshire (a region already known as God's hip pocket :D ) - Rotherham - then all the Morrisons fuel stations are the cheapest. Even so there is 4p difference between them.
Both Rotherham outlets charge 47.9p per litre yet the Doncaster station only wants 43.9p!
Mind you: I put a bit in at a local limo hire company (5th Avenue, off Erskine Road, Rotherham) and it cost £12.50 for 20 litres :shock:
gavbriggs
#142 Post by gavbriggs »
ive found morrisons to be cheapest, my local ish one ia wheelbase at mexborough is at 49.9(jet) and the one at denaby is usually a penny cheaper! worth it if your in the area!
robert-bristol
#143 Post by robert-bristol »
Wow this topic has certainly grown since I started it a year ago.
I am still paying 37.5 ppl for autogas / lpg
It went up by 1p around January but came down by 1p the following month - I struggle to keep up with it. :shock:
