Is a cat necessary for LPG equiped cars?
Just a thought, if I run my volvo on lpg all the time can I ditch the cat, as it sometimes smells on short runs. I guess it would pass emmisions fine on lpg without a cat but what is the legal position?
junkcatcher
martin rowe
- Junior Member
martin rowe
- Junior Member
The fitment of a 'cat' or not is not part of an MOT examination, the only thing is the vehicle has to pass the relivant emission test, whish 1993 on is a cat test, only exception is an LPG equiped vehicle, it has a basic 'non cat' emission test for MOT. take that from an Authorised Examiner, a Nominated Tester & a Quality Controler, oh and MOT staton owner.
martin rowe
- Junior Member
No an LPG car will not pass 'cat' emissions when running on LPG, but an LPG car dose'nt have a 'cat' emission test for MOT, just the old 'non cat' test ie, CO less than 3.5%, HC less than 1200ppm, and it makes no differance weather its a brand new manefacturer supplies car or a 10 yr old self converted one, just make sure the 'LPG' fuel tab is selected on the MOT computer, the system then tells the MOT tester which type of emission test to perform. This is all because VOSA have not had emission limits developed for LPG vehicles.
martinpluss
- New member
Re: Is a cat necessary for LPG equiped cars?
Do you know where I can find an official vosa document that confirms that an LPG car doesn't have a 'cat' emission test? I'm trying to prove this to my tester... My lpg converted 97 range rover has a cat and he is insisting on doing a cat test...
kevintourer
- Junior Member
change your mot testing stn, mine always ask which I would like it tested on.martinpluss wrote:Do you know where I can find an official vosa document that confirms that an LPG car doesn't have a 'cat' emission test? I'm trying to prove this to my tester... My lpg converted 97 range rover has a cat and he is insisting on doing a cat test...
mat_fenwick
- Intermediate Member
Re:
I've found that it can in my experience - admittedly just the once but I put a 1994 Discovery V8 through the MOT where the (expensive to replace) cats had been replaced by steel tubes. I explained the situation and they told me the vehicle should be tested on the fuel it was running on when it arrived (in this case LPG) and it passed.martin rowe wrote:No an LPG car will not pass 'cat' emissions when running on LPG
Whether all LPG cars will pass an MOT without a cat fitted is a different question though...
Unless there is something wrong with them and the fuelling is incorrect, they all will. If presented for test running on gas, whether cats are fitted or not is irrelevant (the compulsory fitment is a type approval issue, not an MoT testable one) and it will be tested to the appropriate standard. See http://www.motuk.co.uk/images/non_cat.pdf.
The only tests in the MoT regarding the exhaust system, is does it leak, is it secure, is the noise level not excessive? See http://www.motuk.co.uk/manual_710.htm
Just for interests sake, does removing the cat. improve economy any?
And, would the post cat. lambda sensor detect there was no cat. whilst running on LPG? Does running on LPG still produce too much Nitrogen and Nitrogen Oxides etc.
junkcatcher
Definite Fail
Reasons for failure: Exhaust
a. [b] A part of the system missing [/b] or excessively deteriorated
To me that means the exhaust system must be complete ---- to me that means you can't just throw bits away because you don't like them.
Junkcatcher, taking your logic any car with a non-standard exhaust of any type would immediately fail as parts are missing (in some cases the whole system). So replacing the tailpipe box with an aftermarket one would be an immediate fail as would replacing it with a straight length of pipe. I think you'll find that unless you get an extremely pedantic tester (and you could appeal the fail anyway and I suspect you would win), parts missing means that the tailpipe has dropped off or similar. Actually checking for the presence of a cat isn't in the test, neither for that matter is checking that it has the same number of silencer boxes that it had when it came out of the factory.
