LPG Portsmouth and Isle of Wight area
shinjukumaster
#1 Post by shinjukumaster »
I'm planning a trip to Isle of Wight and found only 2 Autogas stations:
Does anyone know of other facilities, or have an idea of prices in that area?
Green Road Service Station, 43 Green Road, Southsea, Hants, PO5 4DY
Centre House, 20 Daish Way, Newport, Isle of Wight, PO30 5XJ
Entwood
#2 Post by Entwood »
Go-Autogas lists just 1 on the island ...
Vectawarm, Centre House
28 Daish Way
Newport
Isle of Wight
PO30 5XJ
but quite a few in Hampshire, I know there are a couple near the ferry terminal as I've used them myself, I find the
Shell Garage
264 Southampton Road
Titchfield
Fareham
Hampshire
PO14 4BB
the easiest to use as I usually have a caravan on the back on the way to the ferry !!!
Active_Lad
Moderator
#3 Post by Active_Lad »
If you're coming down the M27, there's a Shell Station in Southampton just after the exit off the M3 and a BP not far from Hedge End. Entwood is correct that you have Shell Titchfield but don't forget the Jet in Portsmouth:
Green Road
Southsea
PO5 4DY
jalfrezigazee
#4 Post by jalfrezigazee »
the road round the IOW is about 43miles so a tank full will get you as long way in the area
adebov
#5 Post by adebov »
Active_Lad wrote:If you're coming down the M27, there's a Shell Station in Southampton just after the exit off the M3 and a BP not far from Hedge End. Entwood is correct that you have Shell Titchfield but don't forget the Jet in Portsmouth:
Green Road
Southsea
PO5 4DY
Although it's a few miles off the M3, the Flogas depot at Romsey was selling @ around 50.3ppl a couple of weeks ago.
