Omega 2.0 stalls on transition
dory
#1 Post by dory »
My 1999 Vauxhall Omega has a Romano single point system (regulator serial no. 10140). It starts and runs fine on petrol, and runs fine on LPG. However, it often stalls when it tries to transition from petrol to LPG. This is much less likely to happen if I run the car for several miles first, so I assume it's trying to change too soon. I have reduced the spark plug gap to 0.030" but this has not made any difference.
Ideally I would like it to transition early and reliably, but late and reliably would be acceptable. Any suggestions?
Dave, Northampton
woody
#2 Post by woody »
what control system does it have???
cheers Keith
www.gastech.org.uk
dory
#3 Post by dory »
omvl millennium
woody
#4 Post by woody »
Change the threshold for change over to 2000 rpm in deceleration.
Change to gas before driving , if it does,nt stall you have cracked it,if not back to the drawing board.
cheers Keith
www.gastech.org.uk
dory
#5 Post by dory »
Thanks Keith, that sounds promising!
I'm new to this but I assume I either need to buy some extra equipment to make this change, or I need to take it to a LPG garage.
MarkJones
#6 Post by MarkJones »
dory wrote:Thanks Keith, that sounds promising!
you need the software available here ...
http://www.vogelsautogas.nl/
press on documenten at above site
look for omvl milenium
you change the language on the header bar once installed
and a laptop.
plus the interface lead /...about £48 from FES north wales
all the best.mark
dory
#7 Post by dory »
Excellent. I've downloaded and installed the software. I'm getting quite excited about this! I have found a cable with USB on one end and Millennium connector on the other on ebay (Item 270167577023) for an opening bid of £4.99 so we'll see what that goes for. Hopefully less than £48.
You've been a great help Keith. Thanks a lot!
MarkJones
#8 Post by MarkJones »
whoops take your post down ..before someone else sees it
then you be paying a lot more for it
all the best.mark
dory
#9 Post by dory »
The problem seems to be getting worse. It used to occasionally stall on transition, now it usually stalls on transition. Today I finally got the cable (£50 in the end) and have and downloaded the software. I changed the switch-over speed from 1600 rpm to 2000 rpm. It still stalls on transition, however. What should I try next?
MarkJones
#10 Post by MarkJones »
should of took your post off as advised ...then you may have e got it for £4.99...
ahh well ...
something on the software says ...
in F3 sensors section ..
gas electro valves opened in advance ....
make sure its ticked ...then save ...
all the best.mark
dory
#11 Post by dory »
I tried to take your advice, Mark, but couldn't find a way to take down my post! I have looked for the "valves opened in advance" setting you mentioned but couldn't find it. The closest setting I could find was 0.4 seconds duration of fuel overlap. Is that it? Maybe we're using different software.
Here are the settings I have at the moment. The only one I have changed is the switch-over speed from 1600 to 2000 rpm.
Vehicle Configuration Screen
Ignition type or number of cylinders: Dual Coil
Type of Petrol-to-Alt-Fuel Switchover: Deceleration by using TPS
Petrol-AltFuel switch-over RPM: 2000
Duration of fuel overlap: 0.4s
Type of Alt. Fuel level indicator: A.E.B.
TPS type: Linear 0-5V
O2 sensor type: 0-5V (type B)
O2 sensor reading delay (open loop mode): 5s
Type of O2 simulation: Standard square wave
Yellow wires utilization: Disconnect injectors
Optional Configuration parameters: Petrol Alt Fuel Switch over Screen
Fuel switch over temperature: 15C
Over rev option: unchecked
Automatic switch over to petrol on low level: unchecked
Optional Configuration parameters: Actuator Screen
Optional default lock: checked
Default lock value: 80
Idle opening steps over default: 20
Idle closing steps under default: 30
Out-of-idle opening steps over default: 35
Out-of-idle opening steps under default: 40
Full throttle option: unchecked
Optional Configuration parameters: TPS Screen
Idle TPS hysteresis: 0.14
Vehicle parameters display screen
O2 sensor: 0.02 V
TPS: 1.3V
Gas level: 195
Actuator position: 0
I could really do with an instruction manual but I can't find one on the Internet.
Dave
woody
#12 Post by woody »
Early Omegas had this type of sensor , the easy way to tell is check the colours on the lambda it will have a red , white , yellow,black wire.If i remember rightly the yellow is the signal wire..
Try setting the fuel overlap at a higher value , say a second.
cheers Keith
www.gastech.org.uk
dory
#13 Post by dory »
Yes the O2 does indeed bounce around when it's running on LPG, and the actuator is on 50 when it idles at 900 rpm.
I increased the fuel overlap to 1 second but it still stalls. I'll try a longer overlap. Is it possible to make it too long? What would be an upper limit do you think?
dory
#14 Post by dory »
Thanks for such a helpful reply Ross. I'm learning a lot from you all!
I have found a PITAGORA emulator which has two push switches and a pot on the bottom. I have taken it out and removed the PCB from the plastic box. It all looks clean as a whistle. The pot moves freely and I'm ready to shift it clockwise or anticlockwise. Anybody know which way makes the overlap longer? If nobody knows then at least I've got a 50% chance of going the right way!
dory
#15 Post by dory »
I bought a new emulator of exactly the same type and the instructions say clockwise makes the overlap time longer. I increased the overlap on the old emulator, then fittend the new emulatoe, then increased the time on the new emulator. None of this stopped it stalling so I've put back the old emulator on the old setting. Anbody want to buy a new emulator?
So, any suggestions for what I try next? :roll:
dory
Problem solved!
#16 Post by dory »
I took it to Finedon Classic Conversions (at NN9 5JA) and Andrew immediately diagnosed a faulty LPG solenoid. £72 for parts and labour got me a new solenoid fitted. Apparently the contaminants in the fuel can build up in the solenoid. Colder weather means stiffer gunk so the solenoid struggles more to operate. That's why the transition got harder and harder as the weather got colder and colder.
Omega now transitions to LPG without stalling. Thanks Andrew!
