Stalling when slowing down and stopping.
cubicincubi
- Junior Member
only when using LPG - when slowing down at roundabouts and junctions - the auto box changes right down before the car is stopped as you would expect - when doing so the revs drop right down from around 1k rpm to about 200 rpm then leap back up to around 800rpm - then if stationary the car will idle properly at around 600rpm. <BR> <BR>but every now and again the revs drop right off and the car stalls - this is a hazard in situations where you keep the car rolling then go to pull away. Happened to the wife on a major intersection and she was left stationary in the middle of the junction stalled. <BR> <BR>I suspect the mixture is weak - may be getting too much air. <BR> <BR>Is it true that the air intake at the front of the vehicle should be redirected into the engine bay rather than take air direct from the airstream? <BR> <BR>any reccomendations. <BR> <BR>thanks
cubicincubi
- Junior Member
sorted. <BR> <BR>when putting the airbox back together i noticed the intake had been modified with a Ford end piece poking into the engine bay instead routed to the front grille. I thought it had been bodged so i fitted a different piece and rerouted it the stock way. <BR> <BR>Just changed it back and it runs fine now. <BR> <BR>although when in park the idle rises and rises. so another thing to fathom. lol. <BR> <BR>at least i'm learning as i go.
- Installer
This is known as <BR> <BR>ram air
