Mercedes Vito 2.0 petrol map request
Hi, I have been running my King system fitted to my 2005 RAV4 2.0 for over 10 years which I fitted myself and was then set up by Simon. I have now got rid of the RAV4 and fitted it to a 2001 Mercedes Vito 2.0 out in Crete, I have the King diagnostic interface, does anyone have a map on file for this vehicle/engine they would be willing to share to help me set it up here in Greece? Thanks in advance Phil
Re: Mercedes Vito 2.0 petrol map request
The map you'd need would depend on engine spec, injector type, injector nozzle size and reference pressure.
If I still have any King map for a Vito it will be on a hard drive I removed from an old broken laptop, we'd be lucky if I could find it. I'm not sure if there have been changes to 2.0 Vito engines over the years, even if I could find a map it could turn out to suit a different 2.0 Vito engine or different injectors. I'm not sure if they made a supercharged Vito engine?
It shouldn't be too difficult to adjust the Rav4 map to suit the Vito?
Thanks for the reply, I will have a look at setting it up, I have an obd to re check fuel trims as it is running, I do have it running on a map I did with the auto calibration feature but it isn't quite there yet. Once I get back to the UK I will book in for a fine tune with you if that's ok?
Thanks again, Phil
Thanks again, Phil
OK, yes that's fine Phil.
