Hello everybody. New member looking for some help. I’m looking for a prins vsi wiring diagram for a 080/70010 loom.
I removed the system from a Rangie p38. I can’t remember how cable 27 + 26 where wired into the loom. Any help or unfit would be appreciated thank you.
Prins wiring loom
Re: Prins wiring loom
https://lpgshop.co.uk/content/lpg-softw ... 0_V2.0.pdf
The wire from pin 27 grey/white wire goes to ignition live, which can be the +ve wire to any petrol injector.
I believe pin 26 red/white wire 'inj module command' goes to the injector emulator/switching unit, which is external of the Prins VSI1 ECU (most sequential LPG ECU's have internal injector emulators/switching units).
