What piping do you use and what fittings do you use to connect that piping to the pump?tom-madbiker wrote: Mon Mar 13, 2023 11:08 pm This is what I use for transfering from a bottle to a tank or similar I keep it in the car on long journeys as an emergency measure too it will fill a 40 litre tank in about 5 mins obviously use at own risk as it's not rated for lpg I have very long wires on mine so I can connect to the vehicle battery to fill also I have a filter in line OSIAS Universal Inline Extern Fuel Pump Fits 0580254910 https://amzn.eu/d/ewv1GQA
Tank filling, butane, 15kg to 3.9kg.
Re: Tank filling, butane, 15kg to 3.9kg.
tom-madbiker
I have to say it was cobbled together I use some clear airline pipe (so I can see the liquid gas flowing) and I modified a European adaptor I had lying around to screw into the car fill point and the usual lefthand thread propane tank fitting it works well however I am going to modify it a bit as I want the car fitting to be on a removable quick release so it's easier to screw it into the car
tom-madbiker
[quote=Pinger
Significantly better than the 1600 Ford X-flow in mine or the subsequent 1800 LET Opel Manta unit that ate headgaskets.
[/quote]
When I got it it had no engine so I had choice and the secu3 is an amazing bit of kit using open source software I have the basic sparks only one (90 quid delivered) but they do one with full sequential injection supporting up to 12 cylinders only problem is they are made in the Ukraine so postage is a bit hap hazard atm there is a forum about it although some of it is in russian
[/quote]
Tom , can i ask , how do you actually connect the line to the pump ? i am assuming its at around 160 psi ? any pictures would be great , or even a vid
tom-madbiker
I just used hoseclips it works well I will dig it out and post a pic
