SWAPPING MY ecu
superkp
SWAPPING MY ecu
#1 Post by superkp »
HI I AM THINKING OF .are the wires colour coded differently on different ecu brands?
superkp
Re: SWAPPING MY ecu
#2 Post by superkp »
sorry meant thinking of swapping lpg ecu
Re: SWAPPING MY ecu
#3 Post by Gilbertd »
Depends what you mean by different brands. If you mean the badge engineered AEB2001 or 2568, so could have a label on it saying King, Bigas, OMVL, Zavoli, etc but the loom and colours will be the same, it will also likely connect to the rest of your existing kit. That assumes the individual manufacturers firmware will have settings for your existing injectors. If you mean the differences between AEB, Prins, KME, AC Stag, LPGTech, etc, then they will all be different.
superkp
Re: SWAPPING MY ecu
#4 Post by superkp »
hi
mine is an esgi the other is a stag 300/6 isa2
if they are different is there a diagram on site
Re: SWAPPING MY ecu
#5 Post by Gilbertd »
Not on here but there is on the AC site https://www.ac.com.pl/download-center-Instructions
superkp
Re: SWAPPING MY ecu
#6 Post by superkp »
thats a great help just need a time to do the job thanks
