WANTED: Matrix 544-17 Injectors
Wanted in working order, Matrix 544 injectors 4 cyl non temp sensor. Thank you!!
Re: WANTED: Matrix 544-17 Injectors
I've got two XJ544 injector blocks that were working perfectly when taken off a 4.0 litre V8 Range Rover. I always intended fitting the complete system to my car and upgrading from the singlepoint but have decided I wouldn't gain much so they are in a box with the rest of the system. Without going to check them (they aren't at home but stored elsewhere) I can't give you the exact number off them but looking at the TT site, they appear to be XJ544-18 and not 17 (https://tinleytech.co.uk/shop/lpg-parts ... der-black/).
