Hi all, finally got round to sorting out the X5 LPG not working. Went to BPV in Slough, they have helped me before on a LPG car. Sam, the LPG expert was terrific. It had many, many problems including a missing Fuse, disconnected wiring, broken wiring, seized Valve and a couple of leaks. He worked methodically and with a sense of humour got it all working. Very reasonably priced and I would recommend them whole heartily if you are having problems.
BPV Servicing & Autogas Slough
An LPG Garage my recommendation - Slough
Re: An LPG Garage my recommendation
Good to hear you've found somewhere near London that isn't a cowboy. They are a Tinley Tech customer and on their list of recommended installers too.
Re: An LPG Garage my recommendation - Slough
I've moved this topic across to the appropiate section and modified the title to help others find it in future. Good to know you got it sorted all the same.
