Haveing pulled out the vaporizer/reducer it was clear it had been sprung a slow water leak. I have the rebuld kit and have fitted all the new elbows, o rings. No problems. With the new flange it should be spot on.
The kit also appears to have come with what appears to be new gas regulation and dispersal parts. Everything inside looks pretty clean apart from some heavy ends. Which I will let drain out. But finding a thin walled 19 mm socket to get it out seems impossible.
Any ideas what tools are nessasary or if its even worth doing? It would be a shame to have these nice new parts snd not use them especially if it might save another rebuild down the line.
Edit hopefully i can add pictures if it will help later.
