Ok so for months things have been 'Ok' no worse than usual. However today on gas the car stutters and hesitates like there is some sort of ignition/fuel/boost cut. I am assuming the easlier two as boost cut is pretty brutal and it feels softer when it cuts in. Car is un-drivable unless you slowly increase the revs, if you need to pull out in a hurry you are done.
Non of this occurs running on petrol.
Folks have suggest coil packs or plugs. Which figures, but they are a shocker to get to (2Hr job at least) also they are iridium plugs and only done a year or so ago. Which leaves coil packs, which I have no idea how to test
Checked the diagnostic codes using FreeSSM ... nothing. Creates a dump of this happening using the BRC software. Anyone fancy telling me whats going on?
https://photos.app.goo.gl/MPtw61sj3uBfNqdj8
Uploading a video so you can hear it ...
https://youtu.be/e8SnWV3z8hU
Thanks,
Probs
