Odd issue with ECU not running right
joshnosh
#1 Post by joshnosh »
Hi all.
Iv got an emer system on an 04 impreza WRX.
It has been alarming out on me all the time.
Laptop showed that the reducer temp was going to minus 33deg. On advice off the tech suport guy at tinley tech (always forget his name) I swaped the sensor. He was right as that sorted it.
Unfortunately the cars still cutting out
I don't know if it had 2 faults or this one developed at the time I fixed the last one
The gas system will switch over every now and then. (Obviously have to turn the ignition of and on to get rid off the alarm befor it will try again.)
But it cuts out after a couple seconds.
Today I had it ticking over on gas on the drive. Whent to move the car and it switched back to petrol.
I noticed the gasses pressure had droped right off
I checked the rear solinoid but there was no voltage. 12v applied showed the valve still works. (Even if it makes a creaky noise when opening)
I could hear gas rushing in.
But the gas pressure didn't increase. I assume the front solenoid bolted to the reducer didn't open
Iv tried changing the "dedicated tank solinoid wire" tick box but that didn't make any difference.
Dose anyone have any ideas what this could be ?
Iv checked the wireing I can see but I can't see it all as it's a bit hidden. Can't see any issues with the bits I can see.
Josh
Re: No gas pressure.
#2 Post by LPGC »
There will be no voltage at the solenoids after the LPG system has switched back to petrol as at that point the LPG ECU will have a;ready turned off power to the solenoids... With a system which switches back to petrol (for any reason) only (say) a second after trying to run on gas you'll only get that (again) second where there will be voltage at the coil.
You've already tried connecting constant 12v directly to the tank solenoid but it's unclear if you've tried the constant feed at the same time you tried switching to LPG?
You have an AEB ECU'd system (only these have the 'dedicated tank solenoid wire' setting in software) and since it's a WRX it'll only be a 4 cylinder AEB ECU. Not all 4 cyl AEB ECU's have separate outputs for the tank solenoid / reducer solenoid but on some that don't have the separate output the option still shows in software. If you try the constant feed again (as above) it may be necessary to untick 'dedicated tank solenoid wire' or to disable on board diagnostics to prevent the system refusing to work on gas without it's tank solenoid wire connected due to the system flagging the detected disconnected tank solenoid wire as an on board diagnostic error (if your ECU is recent enough to feature on board diagnostics). Also bear in mind that on installs with dedicated tank solenoid wiring (that didn't come with Supaseal plug already fitted for reducer solenoid) installers often confuse tank solenoid wiring with reducer solenoid wiring and this can result in OBD errors pointing to the wrong solenoid being open circuit and it doesn't help that some of the wiring diagrams confuse tank/solenoid wiring colours or that some looms mix up the colours.
Creaky noise could be telling, it should just go click in normal use but you can get creaky noises the first time the tank solenoid opens if the line between the tank has been purged of gas (because you ran on gas without supply from the tank, due to tank empty or tank solenoid not open). In which case creaky noise can be normal, as in the sound of liquid gas coming out the tank and evaporating in the line until the line has reached full pressure and is eventually full of liquid gas again.
joshnosh
#3 Post by joshnosh »
So I do normaly just get the cariteristic "ting" when the solenoid engages. I get the creaking when the line is empty after I run it completely dry. Although recently I've noticed it making the noise when it was half full. I assume due to the lines being dryed out.
Iv got open in advanced enabled so the valves normaly come on once the conditions are met and will come on 5 seconds or so before. The lights are flashing like it's waiting to change over. They't seem to be opening though.
I haven't been able to do a test with it hotwired. As I don't have any way to connect to the super seal on the tank. I just pressed some wires onto it. The one at the front is next to the gearbox so hard to get to even with it jacked up.
#4 Post by Brian_H »
If it isn't the solenoids are you sure you haven't caught the pipework somewhere under the car (either by jacking up or debris on it). If its copper rather than poly its likely to kink if so, the creaking you describe is what i'd expect if you had a restriction in the pipe as the pressure after it will be minimal. Assuming the line should be full at that point, if it was an empty tank situation I'd expect it.
It might be an idea to try and verify what pressure your actually getting on the output side - any significant pressure should be able to be felt through the flexible pipes (harder to squeeze).
Equally a gummed up solenoid could cause it, though I'd verify your happy with the coils first (resistance check with a multimeter should help doing this provided you can get to the front one as well)
#5 Post by LPGC »
5 Seconds should be enough to see voltage at the supaseal plug? To 'hotwire' you could just cut the wires to the supaseal and connect a battery to it, can always put wiring back as it was afterwards. But to check if the solenoid is the problem there's no need to do any of this, instead you could remove the plunger from the tank solenoid making the solenoid always open... To do this turn off the manual/service tap on the multivalve, remove the solenoid coil, remove the solenoid post, remove the plunger from the post, refit the post, turn the manual service tap back on, tank now supplies constant feed..
#6 Post by Brian_H »
A further thought - If you have a single hole tank check the valve is actually fully open before you do the above. If its partly/mostly closed that would explain the lack of pressure as well but can allow a small amount through.
joshnosh
#7 Post by joshnosh »
Right gents. About a month ago I took a look at it but haven't touched it since then.
Little odder than originally planned as all previous diagnosis was done with the car warm
Car currently running as follow.
Car starts. Valves ting. Pressure builds up. Lights flashing waiting for temperature. Threashhold reached and it switches over. Lovely.
Except it's not really running on gas it seems to switch between petrol and gas injection all the time. Light stays the same staying it's running on gas
I was accelerating and watching and the gas timings. They where roughly. 20. 0. 0. 0. 22. 21 0. 0. 18. 0.0
Running on gas about 1/4 off the time
At ideal the story is much the same but running on gas 3/4 off the time. Pressure doesn't seem to be too low. It's not bellow the change over threshold at any point.
After around 8 mins driving the car will switch back to petrol completely
Switching the car back to gas. Even after restarting the car or clearing the codes (there aren't any) dose nothing. It just waits to switch over. ECU dosent turn the valves on so no pressure and no switching over. After 10 mins or so it will try to switch over anyway but then immediately fail. And go back to petrol
Car only runs on gas again after sitting for 4 or 5 hours
#8 Post by LPGC »
Have a look in vehicle configuration/gas petrol. If operation an minimum / operation at high rpm with gas partialization are set to anything other than gas you could get switching back to petrol partly or fully at low rpm / when you put your foot down respectively. Also check the split fuel box, this can cause problems if ticked (particularly in combination with an engine that idles with low pinj and some of the other settings below).
Look in modify carb, some combinations of extra injection cutting / extra inj sensitivity and/or high figures in the 2 boxes below will filter short petrol injection pulses to the extent that the gas ECU effectively (for purpose of applying multiplier and correction factors to calculate gas injector pulse length) see zero petrol injector pulse length.
In modify carb, is switching back to petrol for low gas temperature selected?
Where is the system getting engine run (red and white wire) ignition on signal from?
In Changeover is the RPM wire box ticked or cleared? Is the brown RPM wire connected and if so where to?
On software screen in bottom left corner next to the icon of a petrol pump there are 4 'indicator lights', do any of these come on or flicker?
What interface cable, software version and version of Windows (and 32/64 bit) are you running? Some combinations seem more prone to occasionally showing unreal figures on screen than others.. but even with a good cable on totally compatible Windows version you sometimes get spurious readings. Spurious readings on screen are sometimes what the ECU is actually doing (so that would be bad as then the actual fuelling is affected), sometimes the ECU is working on correct readings/figures behind the scenes but just not reflecting the correct readings/figures on screen. In the latter case I've found that sometimes it's possible to lessen spurious readings (if the brown rpm wire isn't connected and 'revolution type signal' box is unticked) by temporarily ticking the revolution type signal box and changing settings in revolution type signal drop down menu and ignition type drop down menu, then unticking the revolution type signal box again. This shouldn't have any effect because when the box is unticked the other settings are greyed out and shouldn't have any bearing on anything, but sometimes this does help prevent spurious readings!
4eyes
#9 Post by 4eyes »
Hi joshnosh. I've got a Subaru outback with a romano system. A few months ago it was randomly switching back to petrol, sometimes 3 or 4 times a day, then be fine for weeks. No codes, nothing wrong, solenoids, valves etc all ok. I changed the battery about 3 months ago and I haven't had the issue since. Apparently Subaru s are famous for acting wierd if the battery is not quite 100%, giving spurious codes on non lpg vehicles too It might be something you can check.
joshnosh
#10 Post by joshnosh »
4eyes wrote: Tue Dec 04, 2018 12:08 pm Hi joshnosh. I've got a Subaru outback with a romano system. A few months ago it was randomly switching back to petrol, sometimes 3 or 4 times a day, then be fine for weeks. No codes, nothing wrong, solenoids, valves etc all ok. I changed the battery about 3 months ago and I haven't had the issue since. Apparently Subaru s are famous for acting wierd if the battery is not quite 100%, giving spurious codes on non lpg vehicles too It might be something you can check.
battery is brand new really. changed a couple months before this issue arose
voltage on system is all looking fine. both via OBD, cig lighter reading and gas ECU
joshnosh
#11 Post by joshnosh »
double posted
joshnosh
#12 Post by joshnosh »
LPGC wrote: Mon Dec 03, 2018 1:07 pm Have a look in vehicle configuration/gas petrol. If operation an minimum / operation at high rpm with gas partialization are set to anything other than gas you could get switching back to petrol partly or fully at low rpm / when you put your foot down respectively. Also check the split fuel box, this can cause problems if ticked (particularly in combination with an engine that idles with low pinj and some of the other settings below).
i had petrol addition enabled
this is purely enabled from a "that sounds like a good idea to have" and "might help cool the valves a little" point off view
car will run find without it
have disabled it for now but no noticeable difference
LPGC wrote: Mon Dec 03, 2018 1:07 pm Look in modify carb, some combinations of extra injection cutting / extra inj sensitivity and/or high figures in the 2 boxes below will filter short petrol injection pulses to the extent that the gas ECU effectively (for purpose of applying multiplier and correction factors to calculate gas injector pulse length) see zero petrol injector pulse length.
both tick boxes where disabled
1.8ms was in the lowest box (extra injection ident time)
i set this to 0 and now the top "led" has stoped flashing. it flashed occasionally when blipping the throttle
probably wasn't causing any problems because it probably only missed a single injection as the petrol injectors went from overrun back to idle or over run to accelration. car is almost never less than 2.2ms on the p.injectors
best to leave it at 0 or return to a default?
as far as i know there are no extras on my car
LPGC wrote: Mon Dec 03, 2018 1:07 pm In modify carb, is switching back to petrol for low gas temperature selected?
yes it is. but set very low 0 degrees i think
LPGC wrote: Mon Dec 03, 2018 1:07 pm Where is the system getting engine run (red and white wire) ignition on signal from?
honestly im not sure as i didn't install it myself. but i know its connected to the ignition (ie they main key)
LPGC wrote: Mon Dec 03, 2018 1:07 pm In Changeover is the RPM wire box ticked or cleared? Is the brown RPM wire connected and if so where to?
connected to the rpm signal in the back off the clock/dial
it did run for about 3 years without it just on the injector setting.
i added the brown wire when i was chasing another problem
disabled the wire and its now running on injectors again. no noticeable change
LPGC wrote: Mon Dec 03, 2018 1:07 pm On software screen in bottom left corner next to the icon of a petrol pump there are 4 'indicator lights', do any of these come on or flicker?
top LED was flickering as per above
bottom LED is coming on sometimes showing red. never yellow
when its Red it seems theres no gas injection times so i assume its switching to petrol.
LPGC wrote: Mon Dec 03, 2018 1:07 pm What interface cable, software version and version of Windows (and 32/64 bit) are you running? Some combinations seem more prone to occasionally showing unreal figures on screen than others.. but even with a good cable on totally compatible Windows version you sometimes get spurious readings. Spurious readings on screen are sometimes what the ECU is actually doing (so that would be bad as then the actual fuelling is affected), sometimes the ECU is working on correct readings/figures behind the scenes but just not reflecting the correct readings/figures on screen. In the latter case I've found that sometimes it's possible to lessen spurious readings (if the brown rpm wire isn't connected and 'revolution type signal' box is unticked) by temporarily ticking the revolution type signal box and changing settings in revolution type signal drop down menu and ignition type drop down menu, then unticking the revolution type signal box again. This shouldn't have any effect because when the box is unticked the other settings are greyed out and shouldn't have any bearing on anything, but sometimes this does help prevent spurious readings!
interface cable is one i made myself from an arduino serial adaptor. cant find the original one i had but this one seems to work perfectly
running windows 10 64 bit
is it possible this is a firmware issue?
im running 16.20 which appears to be the latest.
the issue seems very odd. the ECU simply wont enable the gas tank solenoid once its failed once. i also noticed the ECU disconnects when its failed and you cant reconnect to it or stop the flashing on the switch without turning the car off and on
is it some fail safe mode>?
again no errors or codes shown on the ECU
joshnosh
Re: Odd issue with ECU not running right
#13 Post by joshnosh »
i do note however that the car has always ran with some petrol addition during tip in enrichment during the years iv had it
when the car is out petrol it will run on gas but sharp increase in throttle cause the car to stutter and chug. gradual increases the car will run just fine
joshnosh
#14 Post by joshnosh »
Down graded to 15.90 seems to be working just fine now. Upgraded back to 16.20.
Now it back to not changing over. All co ditions met. But won't do anything.
Back to 15.90 and it's perfect. Injector ratios follow correctly.
Seems like that was the problem. Not unheard off!
#15 Post by LPGC »
Glad it seems sorted.
Should probably have some extra injection filtering enabled on the Subaru but 1.8ms is too high for the ID time (for a Subaru) as they are likely to have actual injection pulses close to 1.8ms under low load conditions. Worth saying just to be aware that some types of issues (such as not filtering extra injection) can mask other issues such as map not rich enough during acceleration.
