Jeep Commander 5.7
Re: Jeep Commander 5.7
#21 Post by LPGC » Fri May 25, 2018 9:28 am
It is rebuildable as a DIY prospect but following rebuild you'll need to set it's pressure again... you see where you're at with pressure using the software.
Ian_Fearn
#22 Post by Ian_Fearn » Fri May 25, 2018 7:08 pm
Hi Simon, thanks for the reply. So I'd need the software for it then?? Not something I've got :(
#23 Post by LPGC » Sat May 26, 2018 4:39 pm
And interface
Ian_Fearn
#24 Post by Ian_Fearn » Fri Jun 01, 2018 10:43 am
Thanks Simon, any idea where I could get the software and cable from??
#25 Post by LPGC » Fri Jun 01, 2018 4:53 pm
You'll struggle to get a copy of genuine Prins software and user code but for Prins VSI1 you can buy a dedicated USB to Prins VSI1 cable and 'Bexprins' (Prins VSI1 ripoff clone software) with user code from suppliers such as LPGShop / TinleyTech.
Bexprins is probably easier to use than proper Prins software for anyone who's not very familiar with Prins, it more clearly describes what settings are for, Prins software is a bit nondescript when it comes to handles for settings.
Ian_Fearn
#26 Post by Ian_Fearn » Sun Jun 03, 2018 8:19 am
Thanks Simon, i'll look into this.
