It looks like i have used the wrong radiator hoses to supply heat to the reducer,works fine when my temp dial is full up inside the car when i turn the heater temp to cold the lpg temp is too low and i have to turn the temp back up in the car.
What would be the best hoses to use to supply the reducer on these BMW X5's M54 ENGINE.I used the top right and bottom right,also tried swapping them around with no luck.......
Also another annoying problem is i have a constant EML light on with burning fail on multiple cylinders,cyl 1 and cyl 5,seems to come and go no idea when it will kick off again once reset sometimes its great for 50+ miles then bam EML again,i've replaced the following trying to diagnose
COILS
2 PRECAT LAMBDAS
NEW PLUGS
CHECK FOR AIR INTAKE LEAKS
TESTED MAF
CHECKED DISA VALVE
Not tested yet
fuel rail pressure
fuel filter
no luck i'm starting to wonder if this is a fuel trim issue due to the lpg upsetting the fuel trims car throws the EML codes on or off LPG doesen't matter even with the LPG totally disabled still the same then bam i'll start it up and it will drive fine for a few days...........really annoying may be a dealer only fix i'm worried.......any help would be great guys.......i've posted a few diagnostics maybe someone could help with interpretation.
