1995 Rover 827 V6 (same as Honda 2.7 V6) running single point, Lambda controlled Leo system with 42mm venturi mixer (changed from 33mm mixer today) with just the purple wire from the Leo connected to the rear bank Lambda sensor as per advice from Gilbertd about not using the grey wire. The vap is an OMVL R90/E but i don't think that's any part of the problem.
This is the problem - every 6 weeks or so, the rear bank Lambda dies (or is killed) and as far as i can see, the only common part is the Leo. If it was overfuelling (due to the previously restrictive mixer) then it would surely fry the front Lambda as well, not just the rear one that i have connected into for the Leo. I run the same wiring set-up on my Jeep with no problems.
The Lambda sensor gives 0.48V output regardless of cold, hot, idle, constant high revs, flooring the loud pedal to intentionally make it rich or on over-run cut-off which would obviously be very lean. There is no cycling up/down round the centre point as it should on petrol and as the Jeep does and also as it did when the Lambda was first renewed.
I tried another Leo unit and that had similar results for 5 minutes then switched back to petrol and wouldn't go back to gas - refitting the original Leo unit restored what i had beforehand.
The only thing i haven't yet tried is disconnecting the Lambda to see if it still shows 0.48V but i have a sneaking suspicion it will.
I have a Millenium ECU that i plan to fit on the Jeep and put the near-new Leo from the Jeep into my Rover with (yet another!) new Lambda
Hopefully this will sort me out! However, i'd like to know if this is a known problem with older, pre-abused Leo ECUs or if it seems i have an oddball fault here?
