wanted cylinder tank < 30 inch
Oldskool
#1 Post by Oldskool »
Anyone want to sell me an inexpensive four hole cylindrical tank ?
max. length 30 inch
max. diameter 14 inch
Don't mind age too much.
Ta
Steve
Re: wanted cylinder tank < 30 inch
#2 Post by LPGC »
Ooh, if you could only go up to 789mm x 360mm, I have lots of those for sale second hand but you'd need to change the valves (preferably) or buy adaptors as these all have forklift fittings.
Ebay item 321947095656
Oldskool
#3 Post by Oldskool »
Thanks Simon, I remember you mentioned those before.
I'm very tight on space but it doesn't need to be a big tank, 30-50 litres would be OK, so hopefully something will come up.
LairdScooby
#4 Post by LairdScooby »
I know this is an older thread but i may have a suitable tank sat in my garage, think it's only a single hole from memory but if you're still after a tank i can double check.
Cheers,
Dave
Oldskool
#5 Post by Oldskool »
Thanks I am still looking for one - I'll PM you.
LairdScooby
#6 Post by LairdScooby »
Thanks Steve - PM replied to with pics etc. :D
Cheers,
Dave
Oldskool
#7 Post by Oldskool »
Dave's tank was a bit too long so I'm still looking.
Thanks anyway Dave.
#8 Post by LPGC »
30" = 762mm,
14" = 355.6mm
Just thinking in case you only counted roughly in inches.. 789x360 wouldn't fit (roughly 31" x 14")?
Or measuring in millimeters might serve better than measuring in inches..
Oldskool
#9 Post by Oldskool »
Thanks Simon yeah I should probably have put it in mm.
A 30" tank would just (only just) fit by modding the chassis a little bit.
I think there's a standard(ish) size 45L tank that's about 28 x 12 (inches again sorry) which would be ideal.
#10 Post by LPGC »
Just check on TinleyTech's site?
Oldskool
#11 Post by Oldskool »
LPGC wrote:Just check on TinleyTech's site?
Tinley don't seem to have quite the right size, but anyway Simon, I thought you knew buying new stuff is against my religion when there's probably a s/h one lying around under someone's bench :)
As it happens I've finally found one - NOS and a price I can easily live with :D
Thanks guys.
#12 Post by LPGC »
Hehe, if I knew you were against buying new I must have forgotten.. I was thinking along the lines a little tank wouldn't be expensive etc.
Anyway, I'm glad for you your holding out has paid off. I know what I think a NOS tank is but you'll have a different definition of NOS (hopefully)?
#13 Post by Gilbertd »
New Old Stock.....
#14 Post by LPGC »
Gilbertd wrote:New Old Stock.....
Ahh thanks for clearing that up mate! I know you knew where I was coming from - nitrous oxide systems was the only thing I thought of that matched with NOS at the time but I knew that must've been wrong :lol:
Anyways, Oldskool and I have since swapped PM's regarding, er, intended application for this tank.
#15 Post by LPGC »
Oldskool wrote:anyway Simon, I thought you knew buying new stuff is against my religion when there's probably a s/h one lying around under someone's bench :)
I didn't put your screen-name to your face, forgot we'd met!
Oldskool
#16 Post by Oldskool »
No worries mate.
LairdScooby
#17 Post by LairdScooby »
Glad you've got sorted with a tank, bonus being NOS as well! I managed to move the tank i had as well so have my space back too - happy all round i reckon! :D
Cheers,
Dave
