Background = VW T25 flat four fitted with an R90 and standard BLOS unit.
Running just fine and recently tuned by a reputable VW T25 LPG installer ( "Campershack").
At this time of year, over on the T25 owners forum, this cold weather starting thing often comes up, (as per here).
My original open loop mixer ring on the Tin-Top never needed the priming thing that goes "turn the key on until the LPG relay clicks off, then repeat, before starting", but when I had the same open loop mixer ring system fitted to the Hi-Top, I did have to do that (only in cold weather). It was never a bother though. I then went to BLOS on the Hi-Top and it stopped needing it, firing up on gas right away, even on icy days. When I sold the Hi-Top I moved the BLOS onto the Tin-Top (removing the old mixer ring of course) and then I did need to prime it a bit
So all of that ^^^ makes it as clear as mud as to what causes the variation. Some folk over on the T25 forum never need to prime (in cold weather), other always have to (in cold weather), even though we are all using R90s and either mixer rings or BLOS.
Around this time of year, I just do the priming thing as a matter of course, only takes less than 10 seconds, so not at all annoying, I'm just curious. I might try and richen the tick over mixture on the BLOS (dead easy) and see what happens, not sure if doing that may throw out the non tick over mixture a bit though. Don't want to be wasting gas running rich across the range, or having to drive ~80 miles to Campershack to get Andrew to put it all straight again
Just wondering what you, dear reader, think about this?
