Hi
Does anyone know the manual calibration settings/piston depth for valtek type 30 calibration?
I have a valtek compatible micrometer, but dont know the standard depth for the piston.
I was planning to use repair kits on all 6 injectors tomorrow but bit apprehensive without knowing the settings, hope someone can help?
Valtek micrometer depth?
Re: Valtek micrometer depth?
Unless these are ten-year old, stroke isn't adjustable anyway?
Measure before you start, and take an average?
It's much more important to have them all alike, than set to any absolute value.
JAMESCRAIG81
- New member
Thanks for the reply!
Ok i maybe wrong abt piston stroke.. maybe should say depth..
Anyway, ok il take the average thanks for the advice.
Any tips as to what to look for when deciding weather i need more or less depth?
thanks
thanks
Not sure what you mean by depth. What are you expecting to reassemble differently than it came apart?
