Sorry if discussed before "vogue v8 petrol vs lpg
Re: Sorry if discussed before "vogue v8 petrol vs lpg
#21 Post by Gilbertd » Thu Feb 26, 2015 4:45 pm
4.4 up to 2005 is the BMW engine, 4.2 Normally Aspirated and Supercharged (and a 4.4 fitted to the Range Rover Sport) fitted to later ones are Jaguar/Ford with valve seats made form I can't believe it's not butter.
To Alun I would suspect if a piston has let go so the rod has been running up and down the bore, the bore will have so much damage there isn't enough metal there to bore and fit a liner. Your best bet is going to be a replacement engine.
Active_Lad
Moderator
#22 Post by Active_Lad » Thu Feb 26, 2015 5:03 pm
Gilbertd wrote:4.4 up to 2005 is the BMW engine, 4.2 Normally Aspirated and Supercharged (and a 4.4 fitted to the Range Rover Sport) fitted to later ones are Jaguar/Ford with valve seats made form I can't believe it's not butter.
Thanks Gilbert. Is there a way of readily identifying the BMW engine as I have my eye on a 56 Plate HSE which could be just a "last of the line" 4.4 BMW or an incorrectly identified 4.2 "utterly butterly" version. Since it's a fair trek to view it I'd rather be sure it's the right model :-)
#23 Post by Gilbertd » Thu Feb 26, 2015 5:22 pm
A BMW engine in an L322
A Jaguar/Ford AJV8 engine in an L322
Active_Lad
Moderator
#24 Post by Active_Lad » Thu Feb 26, 2015 5:26 pm
I think even I can see the difference there. Thanks! :D
#25 Post by LPGC » Thu Feb 26, 2015 6:48 pm
4.4 will be BMW
#26 Post by rossko » Thu Feb 26, 2015 9:16 pm
No, Jaguar created a 4.4 n/a for deployment in the Range Rover ; it would not have been very smart marketing to reduce capacity from the preceding BMW 4.4
#27 Post by LPGC » Fri Feb 27, 2015 4:20 pm
rossko wrote:No, Jaguar created a 4.4 n/a for deployment in the Range Rover ; it would not have been very smart marketing to reduce capacity from the preceding BMW 4.4
I stand corrected! I've only converted maybe 4 of the N/A Jag engine'd L322's (which will have been 4.4's) but have converted maybe 16 supercharged Jag engine'd ones with the 4.2.
Not sure what happened but I'm sure Gilbert's post didn't show before I posted, the pics didn't leave much need to post..
Alun1976
#28 Post by Alun1976 » Wed Mar 18, 2015 11:41 pm
New engine is all in now and running perfect. The gas system works flawlessly except for the fuel level gauge goes the wrong way and totally inaccurate. It also seems to take a lot longer to switch over to gas than the gas system installed in my Z4. I have a cable to plug into my zavoli kit on the Z4 but now need a cable to plug into the KME diego kit on the range rover as I just want to check the fuel trims and make small amendments if necessary. What cable should I go for and where is best to get one from?
#29 Post by Gilbertd » Thu Mar 19, 2015 7:46 am
#30 Post by rossko » Fri Mar 20, 2015 10:09 am
I'm well over half a century old, but people still suprise me. I'd have thought sourcing a £10 lead would be a good idea before installing a fuel system in a multi£K car, let alone driving around with fingers crossed and no setting up at all - whilst complaining at some of the systems behaviour.
#31 Post by LPGC » Fri Mar 20, 2015 10:54 am
rossko wrote:I'd have thought sourcing a £10 lead would be a good idea before installing a fuel system in a multi£K car, let alone driving around with fingers crossed and no setting up at all - whilst complaining at some of the systems behaviour.
Bloomin eck, it does read like Alan installed an LPG system and didn't calibrate it before use.. surprising it works well at all.
Order a cable, Alan, but you might need an OBD live data scan tool to read trims too?
