Do I Need Valve Saver/Flash Lube?
I have a 2004 (04 - 08) Ford F150 4.6l V8 which has had a Romano system installed for the past 9 years. My local installer advised that I do not need a flashlube/valve saver system but can of course have one installed as a precautionary measure if I prefer. So, is it correct that this 4.6l engine doesn't suffer from valve seat recession?
Re: Do I Need Valve Saver/Flash Lube?
How many miles has it done in 9 years, how many sets of valves has it eaten?
It's done around 60,000 miles since the system has been installed, I would assume most of this has been on LPG. No idea whether it has gone through many or any valves in the hands of the previous owner?
I'd imagine it hasn't gone through any then. Removing and putting in new valves is a costly business...
I'm sure it is. So... is it worth investing in some prevention solution or does my engine not require one?
After 60,000 miles, I doubt it.
Out of interest, what's an average mileage for valves to be destroyed due to recession?
Some tests were done on a Honda engine and the valve seats were destroyed within 10,000 miles. It will depend entirely on the particular engine and what grade of steel the seats have been made from. I had a Saab that had done 258,000 when I sold it, almost all on gas, and the head had never been off. So anything between 10 and 300 thousand (although rumour has it that a Ford Zetec engine would last even less time than the Honda one).
Between 10 and 300 haha! I'll follow your and the local installers advice and refrain from spending pounds on lube
