Hi, im currently gas converting the black corsa i did the head on.
The corsa is a 2002 1.2. I've already drilled and tapped the manifold and got the rail all mounted and piped up.
The manifold hasn't got the flaps in the manifold so im presume it's an easier conversion?
The kit is a Ac stag 300-4 the vapouriser is a Zavoli Zeta N and the rail is a omvl fast.
Never done a vauxhall conversion before so just asking has anyone got any pointers / tips they now etc or just point me in the right direction?
Wasn't sure weather to run the lead balls and a valve saver for the price?
Kind Regards
Luke
Corsa c conversion
Re: Corsa c conversion
An easy conversion for sure...
Depending on what nozzles you got with the OMVLs you may need some smaller nozzles.. Some of the Zavoli reducers have a limited range of pressure adjustability - if you got 2.5mm nozzles they're gonna be too large to run at 1.2 bar (depends where you bought the injectors and what the supplier had in stock!).
I believe the petrol pressure reg vac pipe goes to above throttle valve (non vac side) on some small Vauxhall engines but think yous will be conventional relative pressure type - If above the vac pipe it can make for some interesting tuning...
Simon.
Simon.
Thanks simon, the kit is a second hand kit. It has come of an audi A2. The tank is a 50Litre 0 Degree.LPGC wrote:An easy conversion for sure...
Simon.
So as regarding the rails i will have alook once the system is working etc.
Thanks for the info simon.
Kind Regards
Luke
You're welcome Luke,
Must have been the 1.4 A2, so nozzles will probably be OK for the 1.2 Corsa..
- Installer
I'm glad that the kit is second hand or I would have to make comments about about buying the kit and then asking for advice
The 1.2 corsa is as close to an easy conversion you will get
Oh good, i will soon see once i get to the mapping stageLPGC wrote:You're welcome Luke,
Yeah, i didn't want to spend alot on a kit for a 52 plate car tbh, aslong as it works and is safe that will do meclassicswede wrote:I'm glad that the kit is second hand or I would have to make comments about about buying the kit and then asking for advice![]()
cheers
Luke
