Either way, I've taken the car on a nice long road trip this weekend and the problems started within 5 mins of setting off. All was well running on gas and then there was a loud warning noise (three short bleeps followed by a longer one) and the lpg light started flashing very fast and the car went back over to petrol. I pulled over and turned the car off and once started again it was back to working fine.
This problem has slowly gotten worse over the weekend and now the car is pretty much refusing to run on gas at all. I'm unsure whether its a loose connection or whether its to do with how much load I put on the car but it seems to be related to starting from a dead stop and putting my foot down. I've checked as much as I can under the bonnet but there's no obvious issue. The warning beep seems to beep 4 times in repeat and the car will just run on petrol until I turn off and restart. I also had an engine warning light at one point which was misfire on cylinder 8.
On a few occasions the warning beep did stop mid way thru and it went back to running on lpg, but at the moment the lpg is beeping and flashing before I even start the car. It sounds like an old digital alarm clock. I've tried slightly adjusting the pressure on the reducer after I messed up what it was originally set to when I diagnosed the faulty temp sensor. This seems to have no bearing on my problem though. My mpg was also the same on my long run this weekend. 4 miles to £1 when lpg is 63p a litre. This is the same as when using it round town even though the indicated petrol mpg had risen from 14mpg to 20mpg this weekend.
Would be grateful for any advice if anyone has any.
Thanks in advance!
