Jaguar XKR ("new shape") 4.2 supercharged AJ-V8
carl0s
Anybody converted the 4.2 litre supercharged variant of the aluminium-bodied new shape XKR ?
I know the later 5.0 are direct-injection, but not the 4.2 I don't think. There's a little space-saver spare wheel well too.
Carl
Carl
Re: Jaguar XKR ("new shape") 4.2 supercharged AJ-V8
Same engine as the Supercharged Range Rover L322 isn't it? In which case it should convert OK.
carl0s
Yep, I believe so.
Wonder if anybody has experience of issues in terms of space, size of spare wheel well, etc.
Thinking it might be my next project in 2 - 3 years time.
Carl
Carl
- Installer
VSR is going to be the biggest worry
carl0s
aw don't kill my dream!!
is it a big problem on this engine? I wonder if used heads are plentiful just in case?
Carl
Carl
- Installer
Flashlube and a little petrol addition should hold it back
I've converted loads of these engines in the supercharged Rangerovers, a few Supercharged XKRs, some normally aspirated V8 XK's.
Where customers have been tech savvy I've given them the choice of a bit of petrol injection or not but always fitted an electronic Flashlube and had no problems.
Linear high flowing injectors are a must, obviously along with a high flowing reducer (I've used two reducers on some of these).
A petrol return needs to be fitted and (partly because of this) the system must be mapped by reading live fuel trims (never see the same petrol pressure running on gas with the fuel return as you would running on petrol and this obviously effects petrol injection duration).
I have a few tricks for converting these properly, such as using 5mm pipe from injectors to spuds (because 5mm will fit between the manifold and cam covers where 6mm would be trapped) - makes for short pipe runs to injectors and allows injectors to be fitted in there correct orientation and underneath the engine cover.
I don't often connect the OBD up on installs but I do on this engine.
carl0s
Thanks. If I decide to do it, I may give you a shout to install some or all of it.
I may go down the route of hardened valves & seats, although the cost is an eye-watering ~£1,850 from JE Engineering. I haven't looked into it any further though.
I'd probably go for 2x KME Gold & KME Nevo Pro, since I quite like this kit.
I really need to resist the temptation though and get another couple of years out of my 545i. I've only had it on the road since February-ish having spent 6 months repairing & converting it.
I wonder what size tank will fit in the space-saver wheel well of the XKR (new shape X150)?
Carl
Carl
No probs Carlos mate.carl0s wrote: I may give you a shout to install some or all of it
Just had a look to see what I've fitted, must be on other laptop.carl0s wrote:I wonder what size tank will fit
93 litre fits
carl0s
That can't be right. In the spacesaver spare-wheel well?hitman wrote:93 litre fits
Carl
Carl
my bad - got confused was thinking supercharged range rover - night shift lol
optimusmotors
- New member
We done 4.2 Jaguar supercharged last couple years...
OPTIMUS LPG SINCE 1995
CALL FEEL FREE MON-SAT 09:00 18:00
0116 2736 123 - 07712 660 662
www.optimuslpg.com
www.optimuslpg.com
Not answering the question. Carl doesn't want to know whether you've done one or not, he wants to know what size tank fits.
- Installer
No photos of any of your work either?optimusmotors wrote:We done 4.2 Jaguar supercharged last couple years...
I don't take many pics either, taken one of this supercharged Rangerover I did. This one has a couple of MJ reducers, I probably wouldn't fit the same reducers in future (have fitted different reducers since) but works really well, runs 100% on LPG even at full power, performance and drive-ability same as petrol.
Talkingcars
[quote="optimusmotors"]We done 4.2 Jaguar supercharged last couple years...[/quote]
Moderator notice :-
This is not an advertising medium - please feel free to have your contact details displayed but if replying to topics be helpful!
Moderator notice :-
carl0s
Anyone let me know what size donut tank they have fitted in the new-shape XK/R ?
Carl
Carl
