D3 4.4 on LPG
Mogwyth
D3 4.4 on LPG
#1 Post by Mogwyth »
On the verge of getting a Discovery 3 V8 4.4 that has a Prins lpg set-up. Its currently in the garage having reconditioned heads fitted due to a valve seat problem, as far as I know it hasn't got valve lube fitted, would it be worth doing this?
2005 Discovery 3 4.4 V8 HSE
Re: D3 4.4 on LPG
#2 Post by Gilbertd »
Definitely, The D3 engine isn't the same BMW unit as fitted in the L322 Range Rover, but is the Jaguar/Ford unit as in the Sport and has valve seats made from butter.
Mogwyth
Re: D3 4.4 on LPG
#3 Post by Mogwyth »
Thanks will find some local to do it and book it in asap.
Mogwyth
Re: D3 4.4 on LPG
#4 Post by Mogwyth »
My local guy has said he cant fit electronic flashlube fro £150 or "German Oiler" for £350, any thoughts is one system really £$200 better than another.
Bill
Re: D3 4.4 on LPG
#5 Post by Tubbs »
There is a sequential si electronik system that does seem very advanced. Electronic flashlube for £150 is also a very good, proven unit. On both I would be asking if it was a multipont type ?
