Thanks to Rossko I have managed to fire up and test my replacement LPG system and electronically it seems to be good
Looking at mounting the components in the car, I can't work out what the top is of the vaporiser.
It looks the same as this one
Is the LPG inlet really on the top or does it not matter? I would like to orient it with the inlet on one side and the outlet top or bottom but I would rather it be mechanically correct than aesthetically if that makes sense.
