This thread follows on from the thread at
http://www.lpgforum.co.uk/viewtopic.php?f=33&t=13484. Just in case anyone wants any background info..
You have removed the nozzles like I advised in the other thread - good.
Your reducer temp should be hotter than 33deg. But since your gas temp is showing 44deg, then either the gas is warming up dramatically in the engine bay, or the gas temp reading is also wrong, or the reducer is in fact running hotter than 33deg.. Since gas loses heat when it turns into a vapour, and since the gas entering the reducer is only at ambient temp, the gas temp out of the reducer will always really be cooler than the reducer temp... How hot is the reducer to the touch? Luke warm and maybe it really is only 33deg. Uncomfortably hot to hold the reducer tightly and it is a lot hotter! Select a different reducer temp sensor until the readings show a realistic temperature...
Now start everything over again - Reset the ECU. Set all the basic settings including the reducer temp sensor that showed realistic reducer temp. Set 1.1 bar working pressure in the system if you can, or the autocal will just detect your 1.1 bar anyway.
If you had any OBD errors on the BMW, drive it around on petrol for a bit,leave it idling for a bit, go for another bit of a drive. Then go through the autocal procedure again. BMW's don't seem to settle into their usual set of fuel trim registers until a while after OBD codes have been cleared.
