Lpgtech no rpm reading
killerwhat
#1 Post by killerwhat »
Hello all
Just replaced an old pharos system on my hyundai trajet with an lpgtech mini system. All has gone well but i have no rpm reading on the software. I have injector readings and lambda and temp etc but no rpm. The wiring scheme shows a brown wire to the coil but my loom has no brown wire!
Any thoughts ?
john_d
Site Admin
Re: Lpgtech no rpm reading
#2 Post by john_d »
killerwhat wrote:Hello all
Any thoughts ?
ask the place you got the kit from?
Ford Tourneo
Nissan Primastar
gazpo
#3 Post by gazpo »
Hi, I found my 'brown' wire that had a black sheathing over the top so it looked like a normal black wire. Have a double check of your black wires to see if the coating pulls back a little to reveal the brown underneath.
Caused mine to not turn on as someone had connected to battery earth!!
Hope that helps
Garry
kbs
#4 Post by kbs »
killerwhat
#5 Post by killerwhat »
Found it!
All working fine now.
This system is so easy to set up.
