Gilbertd wrote:LPGC wrote:
but does removal of an inspection cover really imply dismantling? If so, this could be included in the next MOT update.
Not a hope in hell. As soon as an MoT tester removes anything there is a danger that he can't fit it back, or shears a bolt in trying to remove it. His liability insurance premium then goes through the roof because of a greater risk of a claim. This would affect every MoT testing station, do you honestly expect VOSA to force that on all of their testing stations? There'd be a riot!
LPGC wrote:
None of us on this forum are MPs, write bills or write Acts of Parliament, very likely none of us fully understand the jargon or processes.
Speak for yourself. There's more than one Statutory Instrument that I had a hand in writing. Consequently I know the process, how long it can take and how easy it is for it to time out and be consigned to history.
Here you're talking about a minor/none point anyway... Removing an inspection cover on a tank involves half a twist on a plastic multivalve inspection cover - and you can see everything under the cover anyway without even removing the cover! Or on a 4 hole tank it involves undoing a hand tightened bolt. And what is there to check underneath the cover? Rosko reckons the PRV. I have said the PRVs are fitted to all multivalves. I will add that without a PRV in a 4 hole tank there is a gaping hole that would let the gas out. None of you really believe that a tank might not be fitted with a PRV, none of you really remove PRVs during any check. You make a none point.
Didn't realise you were involved in writing Statutory Instruments Gilbert - But seems to me the only thing we have Statutory in this industry are the BS Standards. There is nothing official regarding UKLPG in the eyes of the government when it comes to vehicle LPG conversions. Or have you seen something in all those papers Rosko linked to that says otherwise? And if so, why is it still the case that by law UKLPG need not be concerned with any vehicle LPG conversion? In contrast, those Statutory Instruments you had a hand in writing relevant to your trade are enforced in law and punishable even with jail time are they not? I can understand that these things can time-out and never make legislation - But I believe in this argument you fully see my points and are simply going along with your buddy... If mine and Rosko's roles were reversed you could make quite the opposite case eh?
I have reconciled my points on this... If an MOT tester is found to be doing an MOT incorrectly or passing a vehicle that should fail he might be put out of a job by Vosa and in addition will be doing a criminal act.
Quite correct but that isn't the point I was making. The point I was making was that an MoT tester can test his own vehicle and declare it meeting the requirements. A UKLPG member can test his own work and declare it as meeting the requirements. What is the difference? If VOSA do not consider it necessary to bring in a ruling saying that a tester must have his own vehicle tested by somebody else then why should they treat an LPG installer any differently?
The difference is that if the MOT man passes his own vehicle when it should fail and is caught, he may have broken the law and be punished, he may lose his business. A UKLPG member found to have broken UKLPG rules has not broken the law, cannot be punishes except for losing his membership of UKLPG. And if he loses his membership of UKLPG he can simply ignore UKLPG and continue to convert vehicles - then if he wished can phone his mate and still have his installs registered with UKLPG. Vosa have far more than TWO people to keep tabs on all the testers, those people have the backing of Vosa and the law behind them. The two people from UKLPG have only a trade body that doesn't have any teeth behind them. Very big difference!
Why are UKLPG saying that installs done by none members may not be safe?
Because it is quite correct. For someone that says he used to teach English you seem to have a very poor understanding of it. They are saying that installs done by non members MAY not be safe, but they MAY be perfectly safe, equally installs done by members MAY or may not be safe either.
No need to mock me again Gilbert, you've fallen foul before when trying that. Still smarting from the Churchill quote?
.This is hardly a substantial point from UKLPG is it? An install may not be safe full stop, therefore an install not registered with or fitted by a UKLPG member 'may not be safe'? What you are explaining here is that UKLPG might as well not have said anything... If a UKLPG member flips a coin it may land heads up, if anyone else flips a coin it may land heads up.... Anyone reading this will realise that this kind of talk from UKLPG is designed to give the impression that a UKLPG install is likely to be safer - that was the point people will have expected you to have answered.
What you're saying here, then, is that DVLA won't accept an LPGA cert / UKLPG registration for purpose of changing logbook fuel types, but will accept a receipt of conversion from any installer irrespective of the installer's membership of any trade body.
They will accept an invoice or a certificate from the installer, whether it is a LPGA/UKLPG certificate or one that someone knocked up in Photoshop. I understand that they will also accept an invoice from a kit supplier if the owner has fitted the kit himself. What I do not know is if they will accept the fact that the vehicle is on the UKLPG Register as proof but I do know that they don't accept the fact that a vehicle has been MoT'd running on LPG so is shown as dual fuel on the VOSA database. Different departments, no interface between them.
You also claim that the fuel type entry on the V5 is so highly important to the fire service but if they go to a vehicle fire it is a vehicle fire. They don't bother checking the details, they go to put the fire out (or hose down the road after it has burnt out). There are enough videos on Youtube, and some that have been linked to on here in the past, that show that a vehicle fire involving an LPG fuelled vehicle is actually safer than one involving a petrol tank. A petrol tank does nothing then suddenly explodes, an LPG tank does nothing then the PRV opens and the gas burns off in a much more controlled fashion.
Don't you find it a bit surprising that government departments will accept an invoice from an installer, and maybe as you say even a receipt for parts bought that were then fitted on a DIY basis, but in your case would not accept an LPGA / UKLPG certificate - What does this say about the standing of LPGA / UKLPG in the eyes of government departments? Do you think DVLA staff would know to check or bother to check a private trade body website for proof of an LPG conversion when they wouldn't accept a written LPGA / UKLPG safety document? Do you think it rather more likely, and more logical, that they would accept proof from an MOT tester -
SimonHobson wrote:I think one of the options I was offered was to send them a letter, on headed paper, from a garage which stated that the vehicle had been altered. My MoT place has done that for me in the past
like Simon Hobson does?
I claim that having the actual fuel type on the V5 is a common sense way to add to safety. At the moment V5 info is of no use to the fire brigade because it seems people often don't bother to change V5 fuel types and the law regarding having the correct info regarding fuel types on V5 isn't enforced strictly enough. What does a diesel tank do - Now imagine the difference if the diesel is fitted with an LPG tank too... If V5 fuel types were strictly enforced then the fire brigade could make use of the accurate information on V5's. If MOT stations were involved in the process then very quickly all V5s would accurately reflect actual vehicle fuel types - You know this makes sense, and UKLPG's scheme cannot hope to achieve it, but you're playing along with your mate again? We have discussed government departments recently - Remember how DVSA has taken over from both Vosa and DVLA. Driver and Vehicle Standards Agency sounds just the government body to be concerned with both MOTs and logbooks.
Brian_H wrote:And with the wheel nuts point - How do you check if there are wheel nuts behind a hubcap etc then without dismantling? The main reason for no dismantling is the risk of breaking something in the process which is a point that seems to be lost on certain people...
How about not dismantling hubcaps and only failing a vehicle if the MOT man can see there is a missing wheel-nut? The dismantling point wasn't lost on me Brian, but I'm talking about things that are obviously missing - How about on a normal car that has 4 wheel nuts and the MOT man can see one wheel nut is obviously missing? Now Rosko claimed that tank valves need to be dismantled to check for the presence of a PRV. You cannot buy a multivalve without a PRV. A UKLPG member has no way of checking an existing PRV. So Rosko's point was a bit of a null point really eh? And this was the only bit of 'dismantling' he could come up with in his 'dismantling' argument against my MOT check idea. Are you sitting in the 'clutching at straws in attempt to find fault with common sense' corner too then? Are you a UKLPG member Brian?
rossko wrote:LPGC wrote:
What did I make up before?
Short memory. Shall I make a list? It would take a while.
Humour me! To start you off - the forklift thing was one from the beginning of this thread but I'm sure you remember it, it was one of your few points won. Since then you have digged up all sorts of 'papers' and acts yet none of them says UKLPG have any rights to implement any sorts of rules on the vehicle LPG conversion industry or even to be involved in the industry. In contrast, the MOT system is very much involved and is mandatory.
NigelD wrote:LPGC wrote:
I'm asking why you bothered to link to Acts of Parliament that don't say UKLPGs scheme is to become mandatory?
Explained three times already.
Part of the Act is directly and explicitly concerned with certification of gas conversions on vehicles.
I felt that just maybe that could be vaguely related to the discussion.
Does anyone else understand what is eating him here?
It isn't though - because it isn't mandatory - it is just as legal to completely ignore UKLPG as it is to involve UKLPG in any way. Yes or no answer.. Are you saying there is some law that says UKLPG must be involved? The answer is NO isn't it... So why bother bringing up 'Acts' etc when you know that they are not relevant? On the other side of the coin - Interesting that government are obviously fully aware of UKLPG, have done a lot of talk about UKLPG, and STILL have not made UKLPGs schemes mandatory for vehicle LPG conversions. Your points regarding 'Acts' etc are seemingly designed to confuse the issue, again to make UKLPG look more official in the eyes of anyone reading this, again to steer talk away from common sense.
Look again at page 19 Rosko.
Alright, just for clarity: the following is the total extent of your suggested installation check, to be carried out at every MoT?
"9b. Claims that MOT testers are not qualified to check LPG systems are far fetched and wishful thinking by UKLPG members. The MOT system has recently been changed to cover LPG systems on vehicles and has always covered aspects such as tank security. MOT testers have already jumped through all the hurdles to become MOT testers, they know their way around vehicles, unsafely mounted components, know that any kind of fuel pipe should not be near the exhaust. The only things that MOT testers might not already be familiar with is that LPG components need to be stamped with E67 and that tanks need to be externally vented. MOT testers already receive updates on test standards. It would not be difficult to include this type of information in such an update."
My bolding, to highlight the technical content from the padding.
Did you quote the wrong bit on purpose? Page 19 again...
You know very well what I proposed but I will list it again for you here. What I proposed was: (seems this wasn't the first time I told you the gist of my idea)...
1. Instead of most people ignoring UKLPG, everyone ignores UKLPG.
2. Instead of having a scheme that is voluntary and is not backed up by law, we should have a scheme that is mandatory and is supported by law.
3. Instead of installers 'checking' their own installs, the scheme should involve an independent check.
4. The vehicle could be taken by it's owner to a place of the vehicle owner's choosing for this independant check.
4b. Instead of DIYers taking newly converted vehicles to an installer for a check, DIYers simply take their vehicle for the independant check at the same place they would go to if a professional installer fitted their system.
5. Instead of the checks being done by people that are only endorsed by a trade body with no further qualification necessary, the independant checks should be done by people with government recognised qualifiications and government permission to do the checks
6. The people doing the checks should be checked regularly themselves. The people that check the checkers should be employed by a government department and have the full weight of the government department behind them.
7. It is already law that the vehicle V5 accurately reflects the actual fuel(s) that a vehicle uses. This is currently ignored by UKLPG yet if vehicle V5's did accurately reflect the vehicle fuel type the information could prove useful to the fire brigade. This law should be enforced. Any vehicle that has an LPG system should have a V5 that shows LPG as a fuel type. A vehicle described to an insurer as running only on petrol may not be insured if it has an LPG system fitted.
7b. 7 Could easily be enforced. Police already do vehicle checks etc as they drive around. When they see a vehicle with an LPG filling point it wouldn't be too difficult to check to see if LPG is listed as a fuel type on the V5.
8. It should only be possible to change the fuel type on a V5 to LPG after the vehicle has passed the check.
8b. Since any vehicle with LPG listed on the fuel type has now passed a safety check, insurers can rest assured that the vehicle's LPG system has been checked and has been found to be safe.
9. It is possible to achieve all of the above by simply making it compulsory that all newly converted vehicles need to have a new MOT. MOT stations that decide to take part could even be linked to the DVLA to update the V5 to show the new fuel type, or they could issue a written statement to say that the vehicle has been checked and the LPG install has been found to be safe. The owner could then present the written statement to the DVLA.
9c. If anyone has any qualms about 9b, they should compare the situation I propose to the current situation and weigh up the pros and cons of what I suggest to the pros and cons of what we have (or don't have)!
I believe UKLPG would want such a change but individual members would not want this change despite anything they say about safety.
Ah okeydoke, a new tack. The demon is exonerated, now all the lesser demons are to blame. Poor UKLPG, being hamstrung by those awful installers like that. (remember that 'members' are the likes of Calor)
Hardly a new tack, I've said similar before. Do try to remember that nobody here is concerned with the LPG supply industry - that is quite a different business to the LPG vehicle conversion industry. We are only concerned with the latter... If UKLPG are a positive in the supply industry then that is all well and good. They are not a positive in the vehicle conversion industry. Calor has less to do with converting vehicles to run on LPG as a steel stockholder (who supplies vehicle manufacturers) has to do with the production of vehicles.
I'm thinking about PRVs now.... Wondering how you dismantle them for inspection when the customer brings in a vehicle full of gas?
I don't. If I did, I would throw it away since I don't have the gear to set it.
Think of a reasonable PRV check to make, and how to implement that within the confines of the MoT. There is an existing model for checking, its not difficult, until you put in the MoT setting.
No, you brought up PRV's against my arguments... You explain how you check them. You have just said you don't remove or dismantle PRVs (I already knew that), so what do you do - Check that one exists? You cannot buy a multivalve without a PRV, 4 hole tanks have a specific hole for a PRV. I have never seen a tank without a PRV, have you? You make an empty point,. But let's suppose I agreed with your PRV point - Most installs are not fitted by UKLPG members and are never seen by UKLPG members - so most installs go without PRVs being checked, most installs go without any part of the LPG install being checked at all. Your PRV point would be just one point.... What about all the other safety points? A mandatory system would still be better even if I agreed with your PRV point.
Wondering now why you reckon a PRV offers protection from a rusty shoddy tank - It depends just how rusty doesn't it, because a very rusty tank won't be protected by a PRV?
Yes, that was a poor turn of phrase. It would only limit the burst pressure and limit the size of the bang.
Hung up on PRVs on the forum - I wonder how big a point you make of checking PRVs during any install or check - Clutching at straws. Can you come up with a better point to backup your 'dismantling' claim. What needs to be dismantled to get at what? So far you've only said an MOT man wouldn't be allowed to remove a tank valve cover to check for a PRV - I've covered all the PRV points in this post.
And you can't really tell how thick a tank is unless you have ultrasonic test gear like me. Do UKLPG members need to have ultrasonic test gear?
No. Do you think we should? Do you think the MoT man should, in the brave new world?
That's a question for you to answer - you brought up PRVs and rusty shoddy tanks. UKLPG members can't tell the extent of tank rusting anymore than an MOT man or even Joe Publc eh?
DVLA update ... UKLPG could currently ensure this was done for vehicles on their database but they don't.
clueless. It's up to the vehicle owner/keeper to inform DVLA of relevant changes. DVLA would reject any third party interfering with registration details. Paintshops updating your registration record?
It would be possible to create new legislation for any converters or paintshops to be compelled to inform DVLA. (You'll already know that if you looked at the Act I referenced). They could use that information to prompt/investigate the owner, or ignore it, or whatever.
Is this to be part of your simple scheme too, now?
Hardly clueless - The colour of a vehicle should be accurate on the logbook, by law, but colour isn't a safety issue. You fully recognise that we are talking about safety issues here - You have suggested that if we pushed for any change at all the government might opt for compulsory IVA testing... You wouldn't suggest that for a colour change eh? UKLPG are a private trade body and can impose whatever restrictions they see fit on memberships and on vehicles that get registered on their database. Requiring the V5 to reflect the correct fuel type(s) would be simple for them to implement and would ensure at least all vehicles on their database complied with existing law. I would not expect DVLA / DVSA to link up to spray shops computers, LPG installers computers or UKLPGs computers. But all MOT stations have an existing linkup between their computers and Vosa - read DVSA - The system already exists, would just need a bit of tweeking to make this part of my idea possible. If my idea was implemented, very soon all LPG converted vehicles that get on the road would have the correct fuel type(s) on the logbook.
NigelD wrote:To confirm car checked,i asked if the installer would know that it was happening,not at all was the answer,the installer is only contacted if there are issues discovered.
Very good mate but checks by UKLPG (trade body themselves) are still rare - Figures are around one car converted per member per year... But who checks all the other vehicles that each member converts, the vast majority that are never seen by UKLPG staff, besides the installer member who fitted the LPG system? Apparently UKLPG employ two people to vet new installers before allowing them to become members and to do all these 'anonymous' checks which have only relatively recently even become anonymous.. I'd say they have a bit of catching up to do - and don't have the staff to do so. Consider what would happen if your vehicle was found to be totally unsafe by UKLPG staff - Your installer might then get kicked out of UKLPG but could continue to convert vehicles to LPG regardless. He might have a mate he could phone to register installs on his behalf if he ever got kicked out - Your installer need not involve UKLPG at all, you need not involve UKLPG at all, most converted vehciles on the road have not involved UKLPG at all. My idea would see every newly converted to LPG vehicle checked, not by the installer who fitted the system checking his own work (with maybe a 1% chance of the install ever being seen by a trade body staff member), but by an impartial person who (on behalf of a government department) checks vehicle safety every day, including LPG system safety, that person able to update logbook fuel type details immediately following a vehicle passing the safety check.
