L322 range rover 4.4v8 lpg range
ln69bt
#1 Post by ln69bt » Thu Jan 24, 2019 9:32 pm
Hey iv recently converted my l322 range rover 53 4.4 v8 bmw m62 engine and getting 160 miles to a tank full of log 75 litres does that seem correct
hitman
Re: L322 range rover 4.4v8 lpg range
#2 Post by hitman » Thu Jan 24, 2019 9:43 pm
4.2 sc here get about 190 to 85lt around the town
250 miles to 85lt on the motorway
Hth
ln69bt
#3 Post by ln69bt » Sun Jan 27, 2019 5:19 pm
Sounds like mines correct then as mine is slightly worse on fuel than yours anyway just hoped for a little more doesn t seem much of a saving
hitman
#4 Post by hitman » Sun Jan 27, 2019 7:05 pm
Works out about 23-28 mpg equivalent petrol cost.
Try running on petrol only and you'll appreciate the difference.
#5 Post by Gilbertd » Sun Jan 27, 2019 7:55 pm
It's going to depend a lot on how your drive it and where. In town you'll use a lot more as you will be constantly accelerating and hauling over 2 tonnes away from a standstill, on a longer run at constant speed you'll use a lot less. I've got the older P38 with a 4.0 litre engine and I can get anything from 160 to 220 miles on a tankful.
ln69bt
#6 Post by ln69bt » Sun Jan 27, 2019 9:12 pm
That's basically all town driving Iv had it on petrol a year so I know the running cost lol I think trouble is log isn't half the price or it isn't in lincoln. 69.9p lpg petrol 113.9
#7 Post by Brian_H » Sun Jan 27, 2019 9:42 pm
There isn't a lot of choice near you unfortunately - It can be had 15p a litre less than that elsewhere, but if all you have is garages to choose from your stuck with what you can have. Its supposed to get a bit less per mile, I am getting approx 2/3rds cost vs petrol on the same sort of mileage on a v8 Disco though try to avoid using it around town.
#8 Post by Gilbertd » Sun Jan 27, 2019 10:07 pm
Just looked at filllpg and you'd need to go to Nottingham or Doncaster to get a decent price. Amazes me the variations, I'm in Peterborough and the cheapest I've got is 57p at Flogas going up to 69.9 but in St Ives it's only 55.9 at Morrisons.
