Hose sealing?
57jam89
Hose sealing?
#1 Post by 57jam89 » Wed Jun 27, 2018 10:49 am
Hi all,
Is it ok/can you use some type of sealant on the low pressure side of lpg system, I.e on a 6mm rail connection. I mean useing a bit of sealant on the rail before pushing the 6mm hose on and then doing the hose clip up just to help stop any leaks in the furture?
Re: Hose sealing?
#2 Post by LPGC » Wed Jun 27, 2018 3:28 pm
Just checked phone txts and this forum, replied to your txt too mate.
No, I wouldn't advise using any sealant on low pressure rubber pipe connections.
