Reuse Tank/Mutilvalve in a camper
MaxWiz
#1 Post by MaxWiz » Tue Feb 28, 2017 1:56 pm
Hi, I made good use of this forum when I diy fitted an LPG system to a Nissan Primera. It did an amazing job, ran perfectly on gas for 70k miles but eventually found its way to the scrapyard. I pulled off all the gas kit before it went.
I now have a big Mercedes motor home with loads of space underneath. Can I just fit doughnut tank, multi-valve and filler then add a regulator and switch for the solenoid and to use this to replace my gas bottles in the camper or do I need to swap out the multi-valve for vapour take off?
Re: Reuse Tank/Mutilvalve in a camper
#2 Post by LPGC » Tue Feb 28, 2017 7:16 pm
You need vapour take off multivalve.
