OLD Prins ECU Diagnostics
gascab
#1 Post by gascab » Sat Jan 21, 2017 2:28 pm
Attached is a link to a pic of my Prins gas ecu, I think there's a 3 pin diagnostics connector in the engine compartment.
Can I access any diagnosits. I don't think there's anything wrong, just curious what can be accessed, adjusted, fault codes etc.
It's used in conjunction with a rover MEMS 1.9 petrol ECU on a 1800 Rover K series non vvc engine, for which there is a OBD2 connector that I have an app and interface cable to access diagnostics, fault codes etc
https://postimg.org/image/p2nny6a21/
camaro
Re: OLD Prins ECU Diagnostics
#2 Post by camaro » Sat Jan 21, 2017 10:11 pm
As far as I know you need the Prins software, a computer running win98, with a serial port (or if you are a computer person, get it to pretend to be Win98), and a link lead which is about £30 from Poland. I bought an old cheap win98 laptop just to mess with it = £40 on Ebay. Not sure how well it will work yet as it is too bloody cold!
Simon (LPGC) might be your best bet for info and perhaps software.
gascab
#3 Post by gascab » Sun Jan 22, 2017 12:23 pm
camaro wrote:As far as I know you need the Prins software, a computer running win98, with a serial port (or if you are a computer person, get it to pretend to be Win98), and a link lead which is about £30 from Poland. I bought an old cheap win98 laptop just to mess with it = £40 on Ebay. Not sure how well it will work yet as it is too bloody cold!
Sounds good I've got an old laptop or two spare I can use. And, if I ever do mess things up I've a couple of spare gas ecus that work too. Any chance of a link to the Polish connection please.
Brass Monkeys out there!
camaro
#4 Post by camaro » Sun Jan 22, 2017 2:50 pm
This is a USB one - http://www.ebay.co.uk/itm/NEW-USB-PRINS ... 2026589085
Not sure whether mine is USB or serial, come to think of it - I haven't seen it in a while!
gascab
#5 Post by gascab » Sun Jan 22, 2017 3:32 pm
camaro wrote:This is a USB one - http://www.ebay.co.uk/itm/NEW-USB-PRINS ... 2026589085
